Hi there Alex.
I’m still a bit confused here, as your “pinout”, “close-up” & '“typical” diagrams are conflicting in what that connection does. These types of diagrams are helpful to someone like me who has never picked up a Naze ever, but I fear if I wire a buzzer how your pinout diagram shows, but look at the close-up diagram, that buzzer will be permanently buzzing. I’m also assuming that the Naze gets its power from a bec esc?
Hey, thanks for your feedback, I was pretty sure I updated the diagram to make things abit clearer but not sure what happened, so I will get this updated to make it as clear as possible.
And I see the problem with the closeup diagram, so I will update that, but for the buzzer, that is how you connect it as the software controls when it beeps, its just the closeup diagram (Naze32-Rev6-pinout3.jpg) which is wrong.
Cheers mate. Thought I was going mad when I read through the feed & then looked at the diagrams. I’ll be picking your brains for more info when I’m back off my hols.
Thanks for pointing that out, and you are correct, motor 1 hoes to output 1, 2 goes to 2 , 3 to 3 etc… so I need to get the diagram updated.
Actually surprised it took so long for anyone to spot that mistake! When I build my quads I usually just open cleanflight and use the diagram there for motor/ESC order so did not pick it up on the diagram
first of all thank you for collecting and sharing all this information.
In the pinout-picture it looks to me that the 3.3V have to be fed into the naze-board because the arrow is pointing towards the pin/board.
In the following picture(the closeup of the auxillary connectors) its the other way around: the arrow points away from the board (which I assume is correct).
Hi all.
Nice tutorial.
I’m having problems with my OrangeRx R615X receiver.
I used the BIND channel to use with ppm connection (like everyone said) but it doesn’t work, it doesn’t even power up.
What do i have to do ?
The Rev 5 had 5v and GND exchanged for the PPT connection, making it incompatible with a standard servo connector. It seems the Rev 6 put them in the “correct” order.
Would you have connected your RX with the same wiring as the Rev 5 which would have worked?
If you are only using GPS for position/speed to display on an osd then it is possible. But you can’t use GPS on a 6DOF/Acro board for position hold or return to home etc as that requires an extra compass sensor which you find on the 10DOF/Full boards
wow what a find was looking for a wire diagram and found this THANKS have parts for 2 builds a 400 quad and a 350 hex i have a naza32full and a cc3d what fc should i use in the hex??
