APM 2.6 USB has died [Solved]
Does your X350 pro still work when you try to fly it? If not I suggest that you try to load the arducopter firmware onto the Devo M controller again to see if that will help? Possibly a setting was not saved properly which is cuasing a problem. You can also try to perform a factory reset. If you need the parameter files for the Walkera X350 Pro then please let me know.
