Hi I just got into the drone hobby. My first drones arrived yesterday. A JJRC H12C-5 5MP camera, and a 2016 Syma X5UW 3MP wifi FPV. My question is about batteries. These are the batteries and chargers I bought for the drones.
The first one on the list says it takes 3 hours to charge 4 500mah 25c lipo x5uw batteries but its been longer than this charging plugged into my alienware laptop. It says it should take 3 hrs to charge 4 500mah batteries but all 4 lights are still lit. EDIT Just now the lights went out. I put it on charge between 11 and 11:30 this morning and 3 of of the lights just went out about 2:50p.m just now. The others havenāt arrived yet and Iāve just been using the simple usb charge cable for the drones so far. So which is the fast lipo charger and can someone recommend me.
Basically my question is can i buy a proper fast lipo wall charger to charge all my drone batteries quickly and at once. And which is the fastest one to use?
āKingtoys Syma X5UC Drone Battery, 4pcs 3.7V 500mah Lipo Battery for Syma X5UC X5UW RC Quadcopter Drone+4 in 1 Charger+Adapter cablesā
āDeeRC Upgraded 2 x 3.7V 750mAh 25C Rechargable Lipo Battery for JJRC H12C H12W DFD F181 S181 RC Quadcopter Droneā.
āFLOVEME Upgraded 5 x 3.7V 800mAh 25C Lipo Rechargeable Batteries with X5 Charger for DFD F181 / F187 / F163 / H12Cā
āYouCute 1to6 charger and 4 pieces 3.7V 1250mAh batteries for JJRC H11 H11D H11C RC Quadcopter spare parts accessoriesā
āXCSOURCE 2pcs 3.7V 500mAh 25C Lipo Battery + 2 in 1 Battery Charger for Syma X5UC/X5UW RC Quadcopter BC651ā
Iād like to charge multiple batteries too but I need help. The parallel charge board I have has T connections down the center but the 3S batteries have JST connectors on them. Iāve searched for adapters but all I can find are parts to make my own. Are there no manufactured adapters like I need? Thanks
How do you remove the balance plug from the charger? The 2 top plastic guides lock into the charger port which seems overkill - and pulling it out stresses the crap out out it . Is there a trick to this?
At the charger end, one long side of the white connector has two slots that look a bit like a hockey stick, careful use of a craft knife to widen the slots will allow the battery balance plug (white, 4way for a 3S etc. ) to plug in and out without any undue force that could weaken the connections
Steve
Hi, Could any one help, I have a B3 Lipo charger. Problem is that I was using it to charge a 3Cells Lipo and when one Cell in the battery got damaged I converted the battery into a 2Cells But I am chairing it in a B3ās 3Cells charging port. would this damage the battery.
When you say you converted it to a 2S battery, do you just mean you are using it as a 2S battery? If you want to convert it to a 2S battery, you will need to disconnect the damaged cell entirely, otherwise when you charge while it is still connected the voltages can trickle between the cells and worst case this can cause a fire (although relatively unlikely)
Hi there. Could you please tell me if this imax b6 mini is able to charge a 4000mah 30C 3S battery with no problem? And about power supply? Should skyrc OEM power supply bem enough? Thanks
