About make a drone. Please help me check if my drone will be a ble to fly
These are my components-
Motor(4)
ESC
https://www.amazon.in/Generic-Folksrc30A-Controller-Quadcopter-Helicopter/dp/B01BTRLVBY/ref=sr_1_1?s=industrial&ie=UTF8&qid=1524589246&sr=1-1&keywords=esc
Propellers-6045(6X4.5) Glass Fiber Nylon 2CW+2CCW-2pairs
Batteries(2)-3s 11.1v 2500 mAh lipo battery
Flight controller-NAZE32 REV6a MPU6500 32-bit 6 DOF/10 DOF Flight Controller
Tx-Rx- FlySky FS-i6 2.4G 6CH AFHDS RC Transmitter With FS-iA6B Receiver - Mode 2
PDB-CC3D NAZE32 F3 Power Distribution Board PDB With Filter BEC Output 5V 12V 3A
& 250-300 mm wooden frame.
I don’t have any other components.
If we should check please upload some Photos so we can rate your build.
Im not too familiar with your ESCs but your parts look fine to me.
Luca :slight_smile:
I haven’t assembled it yet. I just wanted to check if there won’t be any burnout problems. But thanks for answering.
I wouldn’t use those ESCs.
They have simionK firmware loaded on them… Thats very old.
Look for some 30A blheli_s ESCs
Wooden frame ?
For those motors I suggest you rather go with blheli firmware ESC like these ones
https://www.amazon.in/Generic-Favourite-LittleBee-Mulitshot-OneShot125/dp/B074GZX29S
Also your naze32 flight controller is also very old rather try to get sp f3.
Using a wooden frame. I suggest you consider a carbon fiber frame as wood will break very easily if you crash
yes a wooden frame. Won’t that do?
But that naze32 is 10dof
I can’t afford those. They are too expensive.
Will these do-
https://www.amazon.in/Generic-Flycolor-RAPTOR-BLHeli-Multicopter/dp/B06XHKQZWL/ref=sr_1_15?ie=UTF8&qid=1525106635&sr=8-15&keywords=esc
it will work…
but it may not survive a crash very well and be prone to vibrations.
The will work better then SimonK ones… :slight_smile:
Its an old F1 board but if thats what you have use it.
You just wont be able to use a lot of the betaflight features or the faster gyro + pid loop timings.
If you can’t buy something now, I highly suggest you rather save up and get something proper, as buying the cheapest equipment will just cost you more in the long run as it will break sooner.
Buy from Aliexpress.
