Hello.I am Angie from HongKong AlienCopter Technology Co.,Ltd. AlienCopter Bee 450 Multi-Roter Frame is coming. Welcome to know about it.
Alien Copter have released their premiere FPV frame, the BEE. The first thing that stands out and sets this frame apart from any other in its class is it true 100% real multilayer carbon construction, folding
capabilities and vibration isolation system.
- The Bee is a 430mm class H frame design that is optimized for FPV flight with a forward platform for HD cams & FPV gear and a rear platform for ample battery and CG adjustment.
- One of the key features is the Clean-N-Dirty system that uses vibration mounts to isolate the sensitive electronics and cameras from vibration on a rigged upper sub-frame.
- The lower frame supports the super strong 12 layer 5mm motor arms, that also have quick release thumb screws to allow the arms to fold for portability.
- This Kit also included the Alien Copter PDB (power distribution board) that has built in 5V and 12V filtered BEC system for your FC and FPV gear and has an Alien blue LED ring that glows when powered.
- There are lots of FPV H frames on the market and each have their unique features, the Bee incorporates them all in a top level product that is unmatched in construction and strength.
Features:
• True Multi-layer carbon construction
• Clean and dirty vibration isolation system
• FPV gear provisions
• Folding arms for transportation & storage
• Power distribution board with 5V and 12V BEC and blue led
lighting
Specs:
Wheelbase: 430mm
Weight: 303g
PDB: 6S 22.2v max input and 5V and 12V filtered output
Flying time: 10-18 Min
Payload: <=1.3kg
Included:
Bee Carbon frame Kit
PDB with BEC and LED
FC Mounting hardware
Required:
4x 2212~2216 class motors
4x 8~10 inch props
2200~5200mah Battery
Flight controller
4x 20A ESC
5CH radio system
FPV gear (optional)
Skype: wholesale@aliencopter.com
Email: wholesale@aliencopter.com
Phone: 08615013459817
Web: www.aliencopter.com
Factory![quote=“Angie, post:1, topic:759”]
Features:
lighting
Specs:
Wheelbase: 430mm
Weight: 303g
Payload: <=1.3kg
Included:
Required:
4x 8~10 inch props
Flight controller
4x 20A ESC
5CH radio system
FPV gear (optional)
<img src=“/uploads/db5290/794/74b5084f0f31d7b3.jpg” width=“565” height=“414”>
<img src=“/uploads/db5290/795/d436c0931453b9a3.jpg” width=“565” height=“414”>
<img src=“/uploads/db5290/796/851ab3b36f00052d.jpg” width=“565” height=“414”>
<img src=“/uploads/db5290/797/329b6849190cc1a2.jpg” width=“565” height=“414”>
<img src=“/uploads/db5290/798/198c59d743d9a02a.jpg” width=“565” height=“414”>
<img src=“/uploads/db5290/799/66903c9fdf8a37cf.jpg” width=“565” height=“414”>
<img src=“/uploads/db5290/800/62ae94410e51bda0.jpg” width=“565” height=“414”>
<img src=“/uploads/db5290/801/6a1d5cb4fd41cc40.jpg” width=“565” height=“414”>
<img src=“/uploads/db5290/802/c86ac5439c757f6b.jpg” width=“565” height=“414”>
<img src=“/uploads/db5290/793/4a4a82c116853c53.png” width=“183” height=“162”>
Factory!
[/quote]
strong text
