Align M480L Multicopter Super Combo RM48001XT
The new Align M480L is light weight, foldable and has an efficient design allowing for long flight times with high payload. This kit comes with everything you need to get up and flying, just add a transmitter, receiver and battery and your good to go. It comes with robust automatic retractable landing gear ready for full 360 degree aerial cinematography applications.
The M480L is an adaptable Multi rotor , it comes configured with 4 motors swinging 15 inch foldable high efficiency props. In this configuration it can carry a full G3 Slipring gimbal with Mirrorless DSLR cameras such as the Panasonic GH4 for 9 minutes on a single 6s 5200mah pack. Want to carry something heavier like a Canon D5? No problems simply add two arms, motors and ESC’s to the M480L to convert it to an M690 900mm heavy lift Hexacopter. Need more flight time? The M480L will carry up to 12000mah for flight times approaching 20 minutes with payload.
For sport flyers the M480L without gimbal will fly for up to 20 minutes on a single 6s 5200mah battery making it the ideal aircraft for blistering long range FPV fun or just tearing up the sky at the local field.
