APM 2.6 barometer issue
I’m having an issue with an APM 2.6 i got from UT last week, everything seems to work fine apart from the barometer doesn’t give correct readings, it just seems to stay at zero, and when i test it in the mission planner terminal i get the following
anybody have any ideas what is wrong is it a hardware issue?
Could it be a power issue? Almost looks like it isn’t working. I remember reading some people had an issue with the 3.3V regulator or something that effects the barometer.
If you got it from Unmandtech I would suggest emailing him directly. Otherwise contact your supplier
I sent an email to Unmandtech first, just thought I would check on here and make sure I wasn’t doing anything stupid while I wait for a reply.
Based on what you have said here I wouldn’t say you have done anything wrong (unless you took to it with a hammer :grinning:)
The barometer on the APM 2.6 is famous for being easily damaged. I had a similar issue where the barometer wouldn’t calibrate, and everything I could find said that it was fried. As a last chance I used Arduino IDE to perform a EEPROM wipe, and then put all new software on it, and that fixed the problem. If you haven’t tried that yet, try it. It might work.
Good luck!
