Apm 2.6 vs pixhawk 3dr cables compatibles?
I’m about to buy an APM Mega 2.6 and I already run a Pixhawk 3DR…do the APM has DF13 cables or I need to buy Molex 1.25mm cable ?
For exemple the 3DR GPS module has 6 pin/4 pins DF13…can I plug them directly on the APM board ? I think the APM has only a 5 pins socket …
cheers
vincent
The APM board uses different connectors to the pixhack, but pixhawk is much better and newer than APM so I would suggest sticking to a pixhawk autopilot, or if you want something smaller, check out the px4 mini aio board.
