ARFun Pro 95 Review - The Fastest Micro FPV Drone!
The ARFUN Pro 90mm is an incredible micro FPV quadcopter, boasting an all up weight amongst the lightest around. The DYS motors and Gemfan props can put out a combined thrust output of 472g giving this micro quad an impressive power to weight ratio, and that just on 2S. When you are flying this quad you quickly forget just how small it is as you rip through the sky. But with countless other micro quads available on the market what makes this one stand out? The short answer is that the ARfun Pro 95 is fast using decent tech onboard, it runs powerful motors coupled with a lightweight (and to some extent more aerodynamic) frame, which makes it a bit more fragile than other micro quads.
This is a companion discussion topic for the original entry at https://blog.unmanned.tech/arfun-pro-95-review-the-fastest-95mm-fpv-drone/
