Basic fpv kit for Ardupilot 2.6
Would this list of parts make sense as a first fpv kit (for APM). Is there anything I’m missing or that is not appropriate? My real question is, if I just added a 3s battery for the monitor would this work?
http://www.unmannedtechshop.co.uk/wishlist.php?publicwishlist=f1c4259f2e4a464163e4178d0e19e899
Thanks :smiley:
Those items should all work just fine, How are you going to power you FPV system? As depending on that you might need to add some other connector cables, but my guess based on the cable you chose would just be via a separate lipo?
Sorry, I see what you mean, I’ve added the fatshark 1000mah battery. The reason I asked here is because I don’t want to have to order a tiny little cable once everything else has arrived, or save up for it and find I’m missing a crucial part.
