how to setup battery voltage alarm on flight controller
Hi @loushocker444, what flight controller are you using? The other option if you just need something to warn you when your battery is getting low, you might want to consider this battery voltage alarm
im using cc3d just want somekind of warning so as to not drain the bettery all the way and also not to crash
