Hey everyone, I’m looking to improve the range and signal quality of my FPV drone. I’ve heard that choosing the right antenna can make a big difference. Can anyone recommend some good antennas or share tips on what to look for? Thanks in advance!
Hi there! Great question – upgrading your antenna is one of the best ways to enhance your FPV drone’s performance. Here are some top options you can consider:
1. TrueRC Matchstick:
- Type: Omni-directional
- Frequency: 5.8 GHz
- Gain: 3 dBi
- Why it’s great: Made from carbon fiber, this antenna is both durable and lightweight, perfect for improving performance without adding unnecessary weight. It’s also compatible with both analog and digital FPV systems. Available here.
2. Foxeer Lollipop 4 Plus:
- Gain: 2.6 dBi
- Why it’s great: Its compact and stubby design makes it versatile and easy to mount. Like the Matchstick, it works well for both analog and digital setups. Available here.
3. Foxeer Micro Lollipop:
- Gain: 2.5 dBi
- Why it’s great: This antenna’s flexible cable and robust construction make it an excellent choice for high-quality signal retention in a compact package. Available here.
4. Pagoda Antennas:
- Type: Omni-directional or directional
- Gain: Varies depending on the model
- Why it’s great: Affordable and popular among DIY enthusiasts. It’s an excellent entry point if you’re experimenting with different antenna types. Available here.
5. Directional Antennas (e.g., Crossfire, Helix):
- Type: Directional
- Gain: High gain for long-range use
- Why it’s great: These antennas provide focused signal strength for long-distance flights. However, they require precise alignment for optimal performance. Foxeer Echo 2 Max 13dBi Directional Antenna available here.
Hopefully, this helps you narrow down your options!
