Brushless 2700 motor drivers
I am designing a 10 motor 2700 drone/convertiplane, I am using ten seperate motor drivers 30 a, seems silly do you have a 10 driver board or 2 x 5 about 10amps 2s
That looks like a very interesting project, but at thee moment we do not have such driver boards, as we only do 4in1 or 8in1, but thee 8in1 are designed for larger heavy lift drones so are start at around 80A…
My only suggestion would be to design up a small PCB you can use for power distribution as a hub, and then you can connect the individual ESC to that to help cut down on wiring etc…
Kind Regards
THANKS FOR YOUR ADVICE
THIS IS A MODEL of a 12 m wing span water bomber, an entry for this years royal aeronautical society design competition, it has onboard a 1000 hp turboshaft generator
Both canard and main wings rotate into fixed wing flight at high speed and low power consumption
This particular model will be hovering tethered…and probably wont lift its own weight in batteries anyway
I am new to this modelling game, but have bought a cheap 4 rotor drone to smash up and control the thuser packs, I can maybe use the tiny ecs output thru some sort of amplifier with some power transistors
Give me a link to the 8 in 1, 80 amp esc
Again thanks for your help
C us at Home | Future Wind Turbines
It appears that I got muddled up, as we have 50A 8in1 ESC such as this one - NeutronRC X-CLASS 50A 8in1
or this one Tmotor CINE55A 8IN1 ESC
But for your application I would reccomend rather going for individual ESC along with some sort of custom PDB to manage wiring, something along the lines of these ones are great starting points - https://www.unmannedtechshop.co.uk/product/flycolor-x-cross-hv-5-12s-blheli32-esc/
Kind Regards
