Are these parts compatible? Am I missing any parts to complete the drone? I want a camera transmitter and receiver, which would you recommend?
Order Details:
Item |
Price |
Quantity |
Subtotal |
HGLRC Specter F411 1-2S AIO Whoop/Toothpick Flight Controller (w/ 10A 8Bit 4in1 ESC & 400mW VTX) - ELRS 2.4GHz (SPI) |
£59.95 |
1 |
£59.95 |
RadioMaster Pocket Radio Controller - ELRS 2.4Ghz, Grey |
£64.90 |
1 |
£64.90 |
Flywoo TCXO 2.4G ELRS Receiver EL24P |
£13.99 |
1 |
£13.99 |
HappyModel SE0702 Brushless Motor (23000kV, 26000kV) - 26000 |
£6.19 |
4 |
£24.76 |
BetaFPV Meteor75 Air Brushless Whoop Frame - Blue |
£3.95 |
1 |
£3.95 |
BetaFPV ELRS Nano TX V2 Module - 2.4GHz |
1 |
Topic thumbnail image auto generated by ai assistant
That list is a good start, here are some suggestions.
- You dont need the Flywoo TCXO 2.4G ELRS Receiver, as the Specter F411 already have a built in ELRS receiver on it.
- You also dont need the extra ELRS TX, since the radiomaster pocket (ELRS version) also already includes this built in.
- For your frame you will need to add a canopy for your camera BetaFPV Canopy For Micro Camera 2022 - Unmanned Tech Shop unless you plan to 3D print something?
- You will also need some props, batteries (around 300mah 1s), and charger
- You also need an FPV camera and goggles, you can also consider the cheaper VR02 if you want to save some money.
system
Closed
3
This topic was automatically closed 2 days after the last reply. New replies are no longer allowed.
