Can Hobbywing X6 power combo run on 6s battery?
I’m a newbie and learning to build a multi rotor for videography. In the spec sheet of the motor it says 6-12s support and says recommended 12s. But no data for 6s battery (22.2V). What does this mean?
It would help if you can give us a link to the motor etc…
But usually it just means the manufacturer did not provide any data for 6s tests, only 12s tests
http://www.hobbywing.com/goods.php?id=638&filter_attr=
this is the link for power combo system
