I’m using RHCP antennas but if I position the TX one downwards i.e. below the copter deck to increase distance from GPS puck should I change it to LHCP so the spiral now matches with the RX one on the ground?
Steve
That’s an interesting question and not something I have considered before… but I don’t think that will work as even upside down, it will still be a rhcp radiation pattern (although it it upside down) The reason is th3 lhcp is a mirrored version of rhcp which is different to one rotated 180 degrees.
The best way is to just test it…
Thanks Alex @unmannedtech
Thinking about it again, you are quite right, inverting the antenna does not affect the slope direction of the antenna wires so the RHCP is maintained.
Steve
