Compact drone gimbal for FLIR Duo Pro R thermal imager
The Pixy F is a lightweight, palm-sized drone camera stabilizer specifically designed for the FLIR Duo Pro R thermal imaging camera. The gimbal is optimized to maximise UAV flight time, and features a Hyper-Quick Release system for easy rapid assembly. Onboard HDMI and AUX ports provide direct monitoring of camera signals.
With no balancing or tuning required, setup is incredibly fast and intuitive. The sophisticated absolute encoder gives the system a startup time of 2 seconds, with high-precision home position detection even under heavy vibration conditions.
Pixy F is fully compatible with Pixhawk UAV flight controllers for seamless attitude synchronisation.
  • Weight: 0.8 lb (0.36 kg)
  • Dimension: 132(W) x 139(D) x 153(H)
Pixy-F-FLIR-Drone-Camera-Gimbal
