Hello Unmanned Tech Team,
I hope this message finds you well. I’m reaching out regarding the Flyfish Volador series replacement arms listed on your website. I have the VX5 frame and noticed that the VD5 replacement arms are currently in stock whereas the VX5 replacement arms currently are not in stock.
I’ve seen a listing on Aliexpress stating that the arms for the Volador VX5, VD5, VX6, and VD6 frames are interchangeable. However, I wanted to confirm with you if the VD5 arms you have in stock are indeed compatible with the VX5 frame before making a purchase.
Any information you could provide about their compatibility would be greatly appreciated!
Thank you for your time and assistance.
Best regards,
Brogan.
Hi Brogan good day,
To be honest I am not 100% either, so I have asked FlyFish to clarify for us.
As soon as I hear back, I will let you know.
If there is anything else I can assist with, please do let me know?
David
Hi Brogan good day,
I haven’t heard back from flyfish, so sent them another email using an email recommended by our warehouse team.
Apologies for the delay, I will update you as soon as I hear back.
David
Hi Brogan good morning,
We received the following feedback from Danny at FlyFish:
Hello David
I am sorry to reply you so late.
For the VD series frame cannot be compatible with VX series frame.
Because VD frame have front arm (SHorter) and rear arm(Longer),for VX frame,the 4pcs arms have the same length.
For Volador series frame,the below arms are interchangeable:
VX3 AND VX3.5
VX5 and VX6
VD5 and VD6
So the VX and VD series arms are not compatible.
Hope this helps.
David
