Connect to mission planner using Telemetry/OSD Y adapter cable
The Telemetry/OSD Y adapter cable for APM has an FTDI connector with Gnd 5V and Tx, and there are two connectors one with 5 pins which plugs into the telemetry port.
The other connector is a six pin that would theoretically plug into the power source.
I got the Telemetry/OSD Y adapter cable for APM (V2) because my USB on the APM board is goosed.
Do I need to plug in the six pin connector as well as the five pin Telemetry port connector?
I don’t want to wire this up incorrectly.
Help greatly appreciated
Jim
The 5 small pin goes in the Telemetry Port. The FTDI goes to an OSD. The larger 5 pin goes to a telemetry radio. Power comes from the telemetry port.
Thanks Clifton. Is there a diagram anywhere for the procedure? Been hunting all morning and all I can find are posts or videos on how to set up the Minim OSD.
https://code.google.com/archive/p/minimosd-extra/
http://ardupilot.org/copter/docs/common-minim-osd-quick-installation-guide.html
You are a Star and a Gentleman.
