I can not connect my card BF3 and both.
How to Connect Gimbal and Receiver ?
I do not know that.
Please tell us a bit more about your Problem…
Did this work at some point?
What have you tried so far?
Please provide a link of your equipment so it is easier for us to solve your Problem.
Since your Gimbal is just a servo i would simply plug the servos into the Channels on your Receiver which should control the Gimbal.
I think you can also connect it somehow to your FC.
I do not know that.
Please answer my Questions…
If you dont do that im not able to help you…
Luca
I have not done anything until now. Because I do not know how to connect a gimbal.
What FC are you using?
What Receiver are you using?
What gimbal are you using?
Any links to the above would also help
Receiver Radiolink AT10
What is the connection diagram between these three?
what gimbal is this?
With out knowing the model. Its much harder trying to work out the connections
how the connection between these three is done.
AliExpress sells it == RTF FPV Drone Gopro3 Hafif 2-AXIS Fırçasız Gimbal Kurulu Sensörü ile Ücretsiz Hata Ayıklama
Please switch it to english and then copy and paste it
Or copy the Link so we can look up by ourself
淘宝网 - 淘!我喜欢 to Clipboard
OK after a google and Youtube search try this…
Connect the Red and Black power leads to a 3S power source.
You can attach the Pitch and Roll pins on the gimbal to the FC motors port 6 will probably work ok.
Then in Betaflight set up servos on that motor port.
Below are some video links that may help you.
I have a Quad 210 drone. Like I said, I have an SP3 card. Radiolink receiver. Can you give me a connection diagram.
I’ve given you instructions on a best guess of how you should connect up and link to video’s where you can carry out some further research.
thank you so much… :gülümseme:
