I’m trying to build a racing drone and I’m really confused about the frame I should use for my drone, consumer drones are good but they don’t last long. I’m confused between these two frames for now: Armattan Chameleon Frame 5 Martian II 220 220mm 4mm Arm
If you know any better frame then please let me know.
The details of the rest of the parts I’m going to use is the following: DYS F4 Omnibus Flight Controller Racerstar RS30A V2 30A (ESCs) Brotherhobby Tornado T1 1407 3600KV (Motors) Tattu R-Line 1550mAh 95C 4S1P
I’ve done my research, I’m not sure whether will it work or not? So if any of you could help me, that would means a lot.
The Motors seem to be a bit too small…
The Standard Motor size for 5 inch Quads is 2205 (Freestyle 2306 / racing 2207)
Both Frames are great… The Chameleon is a higher Quality Frame but the Martian is a good beginner Frame…
(You can really tell that the Martian is low Budget but the Price is unbeatable)
