DJI O3 Air Unit FCC Range Hack Tutorial with Included HAM File
DJI O3 Air Unit FCC Hack
The DJI O3 Air Unit has just hit the market and already has a hack to unlock its full range potential. For users in the FCC region, the unit delivers the best range out of the box. However, in the CE region, the transmission distance is significantly shorter. DJI’s specs indicate a 10KM range in FCC mode compared to only 2KM in CE mode. These figures are under optimal conditions like flat terrain, no obstacles, and low RF noise.
Unlocking FCC mode boosts the VTX power from a few mW to over 1W. Remember, transmitting above 25mW without the proper license is illegal in many countries, particularly in Europe (CE).
O3 Air Unit Transmission Power (EIRP) and Range:
  • FCC: < 33 dBm | 10KM
  • CE: < 14 dBm | 2KM
  • SRRC: < 30 dBm | 6KM
DJI O3 Air Unit FCC Unlock Tutorial
Disclaimer: All data and information provided in this article are for informational purposes only. Dronetrest will not be responsible for any actions performed by any reader.
Performing the FCC unlock on the O3 Air Unit is identical to the DJI AVATA range hack. Follow these steps:
  1. Create an Empty Plain Text File: Name the file ham_cfg_support (no extension).
  2. Copy to SD Card: Save the file to the root of the micro SD card used in your FPV Goggles 2 or V2.
  3. Restart and Power On: Insert the SD card back into the goggles, restart them, and power them on.
Once completed, the O3 Air Unit will be in FCC mode, providing optimal range regardless of your location.
Download the HAM file here: ham_cfg_support.zip (180 Bytes)
Unlock your DJI O3 Air Unit’s full potential today and experience extended range like never before!
