DJI O4: The Frame That Puts the Fun in Functionality!
Well, chums, if you’re inclined to fit a DJI O4 camera into your AOS V5 frame, you’re in luck! All AOS V5 frames play nicely with the DJI O4, so compatibility woes can take a back seat. We’ve got all the nitty-gritty details you need to get started, from downloading those crucial STL files to mounting the camera itself.
Once you’ve got your materials sorted, it’s time to roll up your sleeves. You’ll want to ensure everything fits snugly—no one fancies a camera that thinks it can take flight on its own. From assembling the camera cage to adjusting the uptilt friction for perfect angles, each step is designed to keep your footage as steady as a Brit in a queue.
And don’t forget, should you require any extra help, we’ve got links galore in the description. You’ll find everything you need to ensure your build is as smooth as a quality cuppa.
If you fancy more insights—or perhaps a distraction from whatever else you ought to be doing—here’s the link to our video:
