Don’t be fooled by the size of the Falcon 120, it will easily scare onlookers as you screech past them! The new Falcon 120 is a dangerous combination of new technology that might blow you away if you are new to this field! The Falcon 120 is the most compact quad I have seen in a while with a smart design using a 4-in-1 20A Cicada ESC, SP F3 flight controller and PDB is one tower stack. The stack is sat right in the middle of the frame which offers you great stability while performing those trick and flips!
This is a companion discussion topic for the original entry at https://blog.unmanned.tech/eachine-falcon-120-sp-f3-racing-quadcopter/
