Hi my Eachine wizard x220 flips over when turn up the throttle. The arming is disabled and I have checked on betaflight and am unable to rearm the drone. Also the drone is flashing red when I am using the throttle.
Did you set the flight controller orientation correctly ?
This happens when there is dry solder problem or your one of motor is bad or not receiving continuous signal
