I’ve installed a new fc and set it up in beta flight.
When I power it up using usb or lipo, my transmitter sometimes does not connect OR it connects and then disconnects shortly after.
I also start getting intermittent beeps (sometimes) which get more aggressive and then the transmitter disconnects.
if your transmitter is too close to your quad it will cause drop outs.
The beeps could be a buzzer alarming because of the RX Loss.
I did not know this. Will give it a try today. Thanks!
Unfortunately no this was not the case.
Do you think that I should try flashing new firmware and maybe rebinding transmitter?
reflashing wont hurt…
Check you antennas for damage and there positions
