The new Feiyu Tech Summon 3-Axis Handheld Brushless Gimbal with Integrated 4K Camera is a great new improvement on previous gimbals and it also comes with an integrated 4K camera so you can get filming those great shots instantly. The gimbal has three working modes; Heading Follow Mode, Heading and Pitch Follow Mode and Heading Lock Mode. The gimbal has a 3-axis control system that supports wide-angle rotation for a broader view and it is manufactured using high-quality materials, making the product reliable and durable.
However, they haven’t skimped on the camera while concentrating on the gimbal. The camera is capable of capturing 4K footage, has a 16 megapixel graphic sensor, has a no distortion lens and has a HD 2 inch display.
Features:
Three working mode: Heading Follow Mode; Heading and Pitch Follow Mode; Heading Lock Mode
Help to reduce unwanted shaking impact to improve photo quality
3-axis control system supports a wide-angle rotation for a broader view
Quick-release adapter makes mounting and dismounting a breeze
Inbuilt LED indicator shows you the power status
Crafted from high-grade metal materials, highly reliable and durable
The body is all made from metal, giving it extra rigidity and great stabilisation.
The camera is designed with built-in cooling technology, thereby reducing the camera operation noise and increasing the quality of the sound.
With the 2 inch HD display at the back of the camera, you can easily capture and compose the best shots for the situation.
There is a flash LED integrated into the front of the camera, therefore allowing the user to capture more details in low lighting.
Record your footage with a click of a button.
Through advanced algorithm improvements and ingenious design, the gimbal has almost the entire range of movement and lessens the effect of gimbal lock.
The Summon incorporates an anti-shake performance, guaranteeing you a stable HD video, even in slow motion.
The gimbal has the full 360 degree movement and so is great for a timelapse video.
With one tap, you can capture a 360 panoramic view and share on social media.
Access a great, multi-level menu with the joystick of the gimbal.
Feiyu Tech have also developed an App so that you can control the Summon from your phone via WiFi.
You don’t need to worry about battery life with this gimbal; you can get 180 minutes of constant filming with the 3000mah battery.
Charge the gimbal via USB or the mobile power pack.
This is a versatile gimbal with a standard tripod screw mount on the bottom for several mounting options!
