‘t install final question before I proceed?
2d - Can I paste diff file to 4.0.2 then paste it as normal - this will remove the PID and filter settings that are dangerous to copy from Question : Should I leave out the serial numbers line also ? I …
This is what Diatone sent me a diff # tune
version
Betaflight / FURYF4OSD (FY4O) 3.5.1 Sep 8 2018 / 05:21:25 (d9fb5ca13) MSP API: 1.40
board_name FURYF4OSD
manufacturer_id
name
name diatone
resources
mixer
servo
servo mix
feature
beeper
beacon
map
serial
serial 2 8192 115200 57600 0 115200
led
color
mode_color
aux
aux 0 0 0 1900 2100 0 0
aux 1 28 0 1875 2100 0 0
adjrange
rxrange
vtx
rxfail
master
set dyn_notch_quality = 5
set dshot_idle_value = 400
set current_meter = ADC
set small_angle = 60
set osd_warn_core_temp = OFF
set osd_cap_alarm = 500
set osd_vbat_pos = 2497
set osd_tim_2_pos = 2519
set osd_vtx_channel_pos = 2456
set osd_current_pos = 233
set osd_mah_drawn_pos = 2508
set osd_craft_name_pos = 2102
set osd_pidrate_profile_pos = 409
set osd_warnings_pos = 329
set osd_avg_cell_voltage_pos = 2433
set vtx_band = 5
set vtx_channel = 3
set vtx_freq = 5732
profile
profile 0
set dterm_lowpass_hz = 80
set dterm_lowpass2_hz = 160
set dterm_notch_cutoff = 0
set iterm_rotation = OFF
set iterm_relax = RP
set iterm_relax_type = SETPOINT
set throttle_boost = 0
set p_pitch = 45
set i_pitch = 56
set d_pitch = 19
set p_roll = 43
set i_roll = 48
set d_roll = 17
set p_yaw = 73
set level_limit = 35
rateprofile
rateprofile 0
set thr_mid = 100
set thr_expo = 95
set roll_rc_rate = 70
set pitch_rc_rate = 70
set yaw_rc_rate = 70
set roll_srate = 75
set pitch_srate = 60
set yaw_srate = 50
set tpa_breakpoint = 1750
In summation my question is can I copy and paste this file after editing out PID settings, filter settings ?
Also should I leave out the serial numbers line & dyn notch quality setting ?
