Hey guys, i am a newbie in this field, and i am trying to build my first quadcopter, and thought of making it as cheap as possible so tried to make a flight controller using arduino uno, but failed, but now i am confused in buying a flight controller board. After a long search, i found Naze32 to be suitable, but i am confused which version of it would be good,
You can probably use both versions…
I personally would stick to the naze32 F3 because i like a F3 board more than a F1
There are also things that cannot be done by a F1 Board, so the F3 Version is probably a better Choice.
If you want to have a very good Flight experience, consider buying the Omnibus F4 V5 …
Just a tip:
Don’t try to use the cheapest parts that you see… You will be disappointed after a while because the cheap stuff is mostly not the best Quality.
Trust me, i wasted hundreds of Euros because i took the cheap stuff and ended up replacing a lot of it and buying better Stuff .
