The FLYPRO PX400 is a foldable, portable, highly intelligent, easy to fly high-performance FPV (First Person View) and auto-follow drone, especially designed for filmmakers and action sports enthusiasts who use GoPro3/4 cameras.
The FLYPRO PX400 automatically follows you wherever you go, whatever you do. It is your personal sidekick, just in case you can’t rent a helicopter and professional photographer to take a video of your black diamond run. The PX400 is also your personal training assistant, allowing you to review what you’re doing right, and where you need to improve. The drone can let you review imagery you never thought possible, and is a great way to encourage others to join your adventures.
AUTO-TAKEOFF AND LANDING
One Key to take off or land, takeoff and landing is easier than ever before, with both functions just a tap away. Tap once to takeoff and your Inspire 1 will hover and transform, ready to start filming. Then tap again to make it transform into landing mode and auto land.
CIRCLE
it makes circular rotations on a set radius and altitude, keeping the camera aimed at your target,even you can adjust the flight speed to spiral or downward spiral.
ROUTES FLITHTS
You can draw arbitrary curves, the drone will fly in the paths by itself, and autonomous landing on after finishing the flight, mainly used in large-area mapping and aerial photography.
FOLLOW ME
It will follow you at a set distance and altitude, and keep its relative position from you. NO manual remote control required during flight, and the camera will keep aiming at you.
LIVE MAP AND RADAR
See precisely where your PX400 is at all times on the live map. The map can be enlarged when needed and shows your most recent flight path.
FLIGHT TELEMETRY
All of the information you need to fly safely is just a glance away. Altitude, flight speed, distance, and more are right at your fingertips.
More than anything else, the FLYPRO PX400 is a really high technology product. You can easily control the PX400 just by installing the freely available app to your smartphone or tablet. Flight control system is supported by an opensource project named Pixhawk.
The FLYPRO brand philosophy is “I Can Fly”, and the developers have designed the product for enthusiasts who just want to fly. Just open the box and it’s ready to go! More importantly, the PX400 operates on a virtual tether which is connected to your smartphone, and this gives it the “follow me” capability. There are six Follow Modes that you can configure and control with your smartphone app. Each one offers a cool choice of options and will deliver stunning results, regardless of your sport. In fact we think you’ll probably want to use all six.
Auto-follow. Will work with almost any sports. In this mode the FLYPRO PX400 will follow you at a set distance, repeating your movement trajectory precisely while maintaining its position at the preset distance and altitude from you. For example, you can set it to keep a 10 meter distance at 4 meters high to the east from your position. Even when you change your direction, the PX400 will stay at the same preset angle from you. We suggest this mode for straight line wakeboard, cable parks, surfing, and some other sports. It will follow you at speeds up to 25 km/h.
Hover and Aim. The Hover and Aim option sets the FLYPRO PX400 in one position above the ground, but constantly points the camera at your smartphone. This fixed and track option is perfect for tight places such as smaller skateparks, narrow forest trails, or for activities such as bungee jumping or base jumping, where clearance from your equipment is important.
Circle. In this setting, the FLYPRO PX400 makes circular rotations on a set radius and altitude, keeping the camera aimed at your target. This is for slow speed or static shots and will capture some impressive footage around your position.
In addition, through APP, you can set any cycling radius, for example, if the subject is a tall building, the building can be carried out through a 360-degree panorama shooting cycling mode, , this will help you select the best shooting angle if you are a director or a video enthusiasts…
5. Routes Flights. You can draw arbitrary curves, the drone will fly in the paths by itself, and autonomous landing on after finishing the flight, mainly used in large-area mapping and aerial photography.
Before the flight route, you can easily set the altitude, speed, APP will measure the expected length of the route accordingly, the flight time is calculated to prevent exceeding the maximum flight time, to achieve the necessary security checks before takeoff.
FPV
Any video fans can improve your shooting skills by FPV to obtain a fine video job, this will make you a real video director, check what you can do with FPV:
High quality video capture, view on immediate shoot
10CH Transmitter with High-definition Monitor
High-definition images transmission in real-time
High-performance data transmission, real-time flight data transmission
Shooting Stability
So you want to make videos that look drop dead awesome, totally professional, and really top-notch. We get that. We designed the FLYPRO PX400 while chanting the mantra “stable, stable, stable.” Okay, maybe it wasn’t exactly like that, but you get the idea. We think stability is important, and we obsess over it.
The FLYPRO PX400 uses a 3 axis gyro-stabilized gimbal with the following features to make sure that your aerial videos are as stable as a tripod on a granite slab.
Here’s what we engineered:
Auto pitch and yaw
the camera will always point at the smartphone;
Horizon alignment (roll stabilization);
Vibration isolation; In other words, your GoPro3/4 footage is as stable as anything, even while airborne, even while flying at 40 km/h, and even while tracking your progress on the slalom. To use the FLYPRO PX400, simply attach your GoPro3/4 to the drone’s gimbal and you’re ready for stable action shots
FPV
FPV aerial perfect Drone working DEVO10, ready to fly, put your eyes flew high-altitude, flying in the air and enjoy the ultimate experience;
Intelligence
High intelligence Drone, able to maintain their horizontal flight, one key to land, never afraid to fly lost, combined with Android App, one key to take-off, and It can fly according to the flight paths you set in advance via APP;
Auto-Follow
Automatically follow, without manual control, automated tracking shot, suitable for outdoors sport like travel, riding, shooting skateboards, wheels, motorcycles, off-road sports, skiing, water sports; You can be part of the first generation of FLYPRO PX400 users, dreamers, and pioneers. You can be the first owner of the PX400.
Advanced Technical
Pro version has optical flow cameras and sonar sensors, the future of technology now can be achieved, do indoor intelligent positioning flight, shooting indoor television video. You can be part of the first generation of FLYPRO PX400 users, dreamers, and pioneers. You can be the first owner of the PX400.
