I’ve been building my Y6 (pixhawk) and everything seems to be going ok. However, I’m connecting a FlySky RC 8Ch 2.4Ghz FS-R8B Receiver, and I’m not sure what I connect to com the RC connection on the pixhawk to the receiver! Is it the battery 3 pins on the receiver? Is this type of receiver compatible?
Thanks for the reply. I think the post relates to another Tx / Rx. However, it’s more to do with the connection from the pixhawk to the Rx. I have checked on another forum, and it seems to indicate that a PPM Converter is required. What do you think?
Sorry about that, I thought you where referring to the X8R for some weird reason !
You will need to use a PPM encoder to use it your FlySky-R8B receiver with your pixhawk, as that RX does not output PPM, but rather 8 individual PWM signals.
