Hello
In the description for the FPV 5.8Ghz Monitor 7inch - 32 Channel it says “This monitor also has a single video output so you can still use video goggles if you want”
http://www.unmannedtechshop.co.uk/fpv-5-8ghz-monitor-7inch-32-channel.html
I took this to mean that the monitor has a video output somewhere which I can plug something else into (eg a portable dvr to record), however unless I am mistaken this doesn’t seem to be the case? the attached cables only seem to be for video (and audio) input, rather than output?
Maybe it’s worth updating the description to reflect this, unless I have missed something
