Geprc Cinelog 35 V2 Drone shakes when flying
Order Number: UT-696453
Product Name: Geprc Cinelog 35 V2
Brand: GEPRC
Hi I have had an issue with the drone since I received it last week, I filled a support ticket last weekend but nobody has responded other than the automated response to say somebody would.
In the interim I contacted Geprc as the drone shakes a lot when flying, as I thought it maybe something easily sorted with tuning or something similar, they watched a few videos I sent and gave me a new CLI to try and asked me to perform a dynamic balance check of the motors, nothing has worked and the drone still shakes, a lot!!
They have asked for it to be returned, but have given an address in China, so I’m wanting to return the product to you and get a replacement due to only having it for a week and reporting the issue after first using the drone.
As on previous page, CLI update, motor direction test, motor dynamic balance check, swapped out props to new set, checked all bolts and screws to make sure nothing was loose.
No change to the flight profile.
Sorry to hear about this, do you happen to have a ticket number so i can look into why you sid not get any answer, as this should not of happened.
As for this issue, in that video, is that a recording from the dji O3 air unit, or from an attached camera? Can you also give me some moee details about the battery you are using ans also let me know your PID/Filter settings in ebtaflight so we can take a look.
As from the looks of the video it would not suggest a hardware fault, but rather a tuning issue (for your specific camera/battery), or it could be something else like a loose battery etc…, but after qe get some more details we can check some things to help you out.
Hi Alex,
Thanks for coming back to me
The ticket number was 131461
I’ve tried a couple of battery types, GN3 6s 1300’s and CNHL 6s 1300’s, so these shouldn’t cause any issues.
The recording is from the air unit as I don’t have a camera attached, as for video, I can send other videos that may give you more insight in the problem I’m getting but there over 20mb, however I can upload them to WeTransfer and send you the link if that’s ok?
PID/Filter settings I’ll have to get back to you with as it’s on a different system, however I haven’t touched these so they should be stock.
Thanks, no need for videos, but would like to take a look as the pid and filter settings just to see. Sending the cli dump is probably easiest actually if you can
version
Betaflight / STM32F7X2 (S7X2) 4.4.2 Jun 14 2023 / 18:36:41 (23d066d08) MSP API: 1.45
config: YES
start the command batch
batch start
board_name GEPRC_F722_AIO
manufacturer_id GEPR
resources
resource BEEPER 1 C15
resource MOTOR 1 C09
resource MOTOR 2 C08
resource MOTOR 3 C07
resource MOTOR 4 C06
resource MOTOR 5 NONE
resource MOTOR 6 NONE
resource MOTOR 7 NONE
resource MOTOR 8 NONE
resource LED_STRIP 1 A01
resource SERIAL_TX 1 A09
resource SERIAL_TX 2 A02
resource SERIAL_TX 3 B10
resource SERIAL_TX 4 C10
resource SERIAL_TX 5 C12
resource SERIAL_TX 6 NONE
resource SERIAL_TX 7 NONE
resource SERIAL_TX 8 NONE
resource SERIAL_TX 9 NONE
resource SERIAL_TX 10 NONE
resource SERIAL_TX 11 NONE
resource SERIAL_TX 12 NONE
resource SERIAL_RX 1 A10
resource SERIAL_RX 2 A03
resource SERIAL_RX 3 B11
resource SERIAL_RX 4 C11
resource SERIAL_RX 5 D02
resource SERIAL_RX 6 NONE
resource SERIAL_RX 7 NONE
resource SERIAL_RX 8 NONE
resource SERIAL_RX 9 NONE
resource SERIAL_RX 10 NONE
resource SERIAL_RX 11 NONE
resource SERIAL_RX 12 NONE
resource I2C_SCL 1 NONE
resource I2C_SCL 2 B10
resource I2C_SCL 3 NONE
resource I2C_SCL 4 NONE
resource I2C_SDA 1 NONE
resource I2C_SDA 2 B11
resource I2C_SDA 3 NONE
resource I2C_SDA 4 NONE
resource LED 1 C04
resource LED 2 NONE
resource LED 3 NONE
resource SPI_SCK 1 A05
resource SPI_SCK 2 B13
resource SPI_SCK 3 B03
resource SPI_SCK 4 NONE
resource SPI_MISO 1 A06
resource SPI_MISO 2 B14
resource SPI_MISO 3 B04
resource SPI_MISO 4 NONE
resource SPI_MOSI 1 A07
resource SPI_MOSI 2 B15
resource SPI_MOSI 3 B05
resource SPI_MOSI 4 NONE
resource ADC_BATT 1 C02
resource ADC_RSSI 1 NONE
resource ADC_CURR 1 C01
resource ADC_EXT 1 NONE
resource BARO_CS 1 NONE
resource BARO_EOC 1 NONE
resource BARO_XCLR 1 NONE
resource PINIO 1 NONE
resource PINIO 2 NONE
resource PINIO 3 NONE
resource PINIO 4 NONE
resource USB_MSC_PIN 1 NONE
resource FLASH_CS 1 B09
resource OSD_CS 1 B12
resource GYRO_EXTI 1 A08
resource GYRO_EXTI 2 NONE
resource GYRO_CS 1 A15
resource GYRO_CS 2 NONE
resource USB_DETECT 1 NONE
resource PULLUP 1 NONE
resource PULLUP 2 NONE
resource PULLUP 3 NONE
resource PULLUP 4 NONE
resource PULLDOWN 1 NONE
resource PULLDOWN 2 NONE
resource PULLDOWN 3 NONE
resource PULLDOWN 4 NONE
timer
timer A00 AF2
pin A00: TIM5 CH1 (AF2)
timer A03 AF3
pin A03: TIM9 CH2 (AF3)
timer C08 AF3
pin C08: TIM8 CH3 (AF3)
timer C06 AF3
pin C06: TIM8 CH1 (AF3)
timer C09 AF3
pin C09: TIM8 CH4 (AF3)
timer C07 AF3
pin C07: TIM8 CH2 (AF3)
timer B06 AF2
pin B06: TIM4 CH1 (AF2)
timer B07 AF2
pin B07: TIM4 CH2 (AF2)
timer B01 AF2
pin B01: TIM3 CH4 (AF2)
timer B00 AF2
pin B00: TIM3 CH3 (AF2)
timer A01 AF1
pin A01: TIM2 CH2 (AF1)
dma
dma SPI_MOSI 1 NONE
dma SPI_MOSI 2 NONE
dma SPI_MOSI 3 NONE
dma SPI_MOSI 4 NONE
dma SPI_MISO 1 NONE
dma SPI_MISO 2 NONE
dma SPI_MISO 3 NONE
dma SPI_MISO 4 NONE
dma SPI_TX 1 NONE
dma SPI_TX 2 NONE
dma SPI_TX 3 NONE
dma SPI_TX 4 NONE
dma SPI_RX 1 NONE
dma SPI_RX 2 NONE
dma SPI_RX 3 NONE
dma SPI_RX 4 NONE
dma ADC 1 NONE
dma ADC 2 NONE
dma ADC 3 0
ADC 3: DMA2 Stream 0 Channel 2
dma UART_TX 1 NONE
dma UART_TX 2 NONE
dma UART_TX 3 NONE
dma UART_TX 4 NONE
dma UART_TX 5 NONE
dma UART_TX 6 NONE
dma UART_TX 7 NONE
dma UART_TX 8 NONE
dma UART_RX 1 NONE
dma UART_RX 2 NONE
dma UART_RX 3 NONE
dma UART_RX 4 NONE
dma UART_RX 5 NONE
dma UART_RX 6 NONE
dma UART_RX 7 NONE
dma UART_RX 8 NONE
dma pin A00 0
pin A00: DMA1 Stream 2 Channel 6
dma pin A03 NONE
dma pin C08 1
pin C08: DMA2 Stream 4 Channel 7
dma pin C06 0
pin C06: DMA2 Stream 2 Channel 0
dma pin C09 0
pin C09: DMA2 Stream 7 Channel 7
dma pin C07 1
pin C07: DMA2 Stream 3 Channel 7
dma pin B06 0
pin B06: DMA1 Stream 0 Channel 2
dma pin B07 0
pin B07: DMA1 Stream 3 Channel 2
dma pin B01 0
pin B01: DMA1 Stream 2 Channel 5
dma pin B00 0
pin B00: DMA1 Stream 7 Channel 5
dma pin A01 0
pin A01: DMA1 Stream 6 Channel 3
feature
feature -RX_PPM
feature -INFLIGHT_ACC_CAL
feature -RX_SERIAL
feature -MOTOR_STOP
feature -SERVO_TILT
feature -SOFTSERIAL
feature -GPS
feature -RANGEFINDER
feature -TELEMETRY
feature -3D
feature -RX_PARALLEL_PWM
feature -RX_MSP
feature -RSSI_ADC
feature -LED_STRIP
feature -DISPLAY
feature -OSD
feature -CHANNEL_FORWARDING
feature -TRANSPONDER
feature -AIRMODE
feature -RX_SPI
feature -ESC_SENSOR
feature -ANTI_GRAVITY
feature RX_SERIAL
feature TELEMETRY
feature OSD
feature AIRMODE
feature ANTI_GRAVITY
serial
serial 20 1 115200 57600 0 115200
serial 0 131073 115200 57600 0 115200
serial 1 64 115200 57600 0 115200
serial 2 0 115200 57600 0 115200
serial 3 0 115200 57600 0 115200
serial 4 0 115200 57600 0 115200
mixer
mixer QUADX
mmix reset
beeper
beeper GYRO_CALIBRATED
beeper RX_LOST
beeper RX_LOST_LANDING
beeper DISARMING
beeper ARMING
beeper ARMING_GPS_FIX
beeper ARMING_GPS_NO_FIX
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper ACC_CALIBRATION
beeper ACC_CALIBRATION_FAIL
beeper READY_BEEP
beeper MULTI_BEEPS
beeper DISARM_REPEAT
beeper ARMED
beeper SYSTEM_INIT
beeper -ON_USB
beeper BLACKBOX_ERASE
beeper CRASH_FLIP
beeper CAM_CONNECTION_OPEN
beeper CAM_CONNECTION_CLOSE
beeper RC_SMOOTHING_INIT_FAIL
beacon
beacon RX_LOST
beacon RX_SET
map
map AETR1234
led
led 0 0,0::C:0
led 1 0,0::C:0
led 2 0,0::C:0
led 3 0,0::C:0
led 4 0,0::C:0
led 5 0,0::C:0
led 6 0,0::C:0
led 7 0,0::C:0
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
mode_color
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 0
mode_color 5 1 0
mode_color 5 2 0
mode_color 5 3 0
mode_color 5 4 0
mode_color 5 5 0
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
mode_color 7 0 3
aux
aux 0 0 0 1750 2100 0 0
aux 1 1 1 1700 2100 0 0
aux 2 13 2 1700 2100 0 0
aux 3 0 0 900 900 0 0
aux 4 0 0 900 900 0 0
aux 5 0 0 900 900 0 0
aux 6 0 0 900 900 0 0
aux 7 0 0 900 900 0 0
aux 8 0 0 900 900 0 0
aux 9 0 0 900 900 0 0
aux 10 0 0 900 900 0 0
aux 11 0 0 900 900 0 0
aux 12 0 0 900 900 0 0
aux 13 0 0 900 900 0 0
aux 14 0 0 900 900 0 0
aux 15 0 0 900 900 0 0
aux 16 0 0 900 900 0 0
aux 17 0 0 900 900 0 0
aux 18 0 0 900 900 0 0
aux 19 0 0 900 900 0 0
adjrange
adjrange 0 0 0 900 900 0 0 0 0
adjrange 1 0 0 900 900 0 0 0 0
adjrange 2 0 0 900 900 0 0 0 0
adjrange 3 0 0 900 900 0 0 0 0
adjrange 4 0 0 900 900 0 0 0 0
adjrange 5 0 0 900 900 0 0 0 0
adjrange 6 0 0 900 900 0 0 0 0
adjrange 7 0 0 900 900 0 0 0 0
adjrange 8 0 0 900 900 0 0 0 0
adjrange 9 0 0 900 900 0 0 0 0
adjrange 10 0 0 900 900 0 0 0 0
adjrange 11 0 0 900 900 0 0 0 0
adjrange 12 0 0 900 900 0 0 0 0
adjrange 13 0 0 900 900 0 0 0 0
adjrange 14 0 0 900 900 0 0 0 0
adjrange 15 0 0 900 900 0 0 0 0
adjrange 16 0 0 900 900 0 0 0 0
adjrange 17 0 0 900 900 0 0 0 0
adjrange 18 0 0 900 900 0 0 0 0
adjrange 19 0 0 900 900 0 0 0 0
adjrange 20 0 0 900 900 0 0 0 0
adjrange 21 0 0 900 900 0 0 0 0
adjrange 22 0 0 900 900 0 0 0 0
adjrange 23 0 0 900 900 0 0 0 0
adjrange 24 0 0 900 900 0 0 0 0
adjrange 25 0 0 900 900 0 0 0 0
adjrange 26 0 0 900 900 0 0 0 0
adjrange 27 0 0 900 900 0 0 0 0
adjrange 28 0 0 900 900 0 0 0 0
adjrange 29 0 0 900 900 0 0 0 0
rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
vtxtable
vtxtable bands 0
vtxtable channels 0
vtxtable powerlevels 0
vtxtable powervalues
vtxtable powerlabels
vtx
vtx 0 0 0 0 0 900 900
vtx 1 0 0 0 0 900 900
vtx 2 0 0 0 0 900 900
vtx 3 0 0 0 0 900 900
vtx 4 0 0 0 0 900 900
vtx 5 0 0 0 0 900 900
vtx 6 0 0 0 0 900 900
vtx 7 0 0 0 0 900 900
vtx 8 0 0 0 0 900 900
vtx 9 0 0 0 0 900 900
rxfail
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 a
rxfail 4 h
rxfail 5 h
rxfail 6 h
rxfail 7 h
rxfail 8 h
rxfail 9 h
rxfail 10 h
rxfail 11 h
rxfail 12 h
rxfail 13 h
rxfail 14 h
rxfail 15 h
rxfail 16 h
rxfail 17 h
master
set gyro_hardware_lpf = NORMAL
set gyro_lpf1_type = PT1
set gyro_lpf1_static_hz = 250
set gyro_lpf2_type = PT1
set gyro_lpf2_static_hz = 500
set gyro_notch1_hz = 0
set gyro_notch1_cutoff = 0
set gyro_notch2_hz = 0
set gyro_notch2_cutoff = 0
set gyro_calib_duration = 125
set gyro_calib_noise_limit = 48
set gyro_offset_yaw = 0
set gyro_overflow_detect = ALL
set yaw_spin_recovery = AUTO
set yaw_spin_threshold = 1950
set gyro_to_use = FIRST
set dyn_notch_count = 1
set dyn_notch_q = 500
set dyn_notch_min_hz = 100
set dyn_notch_max_hz = 600
set gyro_lpf1_dyn_min_hz = 250
set gyro_lpf1_dyn_max_hz = 500
set gyro_lpf1_dyn_expo = 5
set gyro_filter_debug_axis = ROLL
set acc_hardware = AUTO
set acc_lpf_hz = 25
set acc_trim_pitch = 0
set acc_trim_roll = 0
set acc_calibration = 25,-40,-26,1
set baro_bustype = I2C
set baro_spi_device = 0
set baro_i2c_device = 2
set baro_i2c_address = 0
set baro_hardware = AUTO
set mid_rc = 1500
set min_check = 1050
set max_check = 1900
set rssi_channel = 0
set rssi_src_frame_errors = OFF
set rssi_scale = 100
set rssi_offset = 0
set rssi_invert = OFF
set rssi_src_frame_lpf_period = 30
set rssi_smoothing = 125
set rc_smoothing = ON
set rc_smoothing_auto_factor = 30
set rc_smoothing_auto_factor_throttle = 30
set rc_smoothing_setpoint_cutoff = 0
set rc_smoothing_feedforward_cutoff = 0
set rc_smoothing_throttle_cutoff = 0
set rc_smoothing_debug_axis = ROLL
set fpv_mix_degrees = 0
set max_aux_channels = 14
set serialrx_provider = SBUS
set serialrx_inverted = OFF
set sbus_baud_fast = OFF
set crsf_use_negotiated_baud = OFF
set airmode_start_throttle_percent = 25
set rx_min_usec = 885
set rx_max_usec = 2115
set serialrx_halfduplex = OFF
set msp_override_channels_mask = 0
set adc_device = 3
set adc_vrefint_calibration = 0
set adc_tempsensor_calibration30 = 0
set adc_tempsensor_calibration110 = 0
set blackbox_sample_rate = 1/8
set blackbox_device = SPIFLASH
set blackbox_disable_pids = OFF
set blackbox_disable_rc = OFF
set blackbox_disable_setpoint = OFF
set blackbox_disable_bat = OFF
set blackbox_disable_alt = OFF
set blackbox_disable_rssi = OFF
set blackbox_disable_gyro = OFF
set blackbox_disable_acc = OFF
set blackbox_disable_debug = OFF
set blackbox_disable_motors = OFF
set blackbox_disable_gps = OFF
set blackbox_mode = NORMAL
set blackbox_high_resolution = OFF
set min_throttle = 1070
set max_throttle = 2000
set min_command = 1000
set dshot_idle_value = 550
set dshot_burst = ON
set dshot_bidir = ON
set dshot_edt = OFF
set dshot_bitbang = AUTO
set dshot_bitbang_timer = AUTO
set use_unsynced_pwm = OFF
set motor_pwm_protocol = DSHOT300
set motor_pwm_rate = 480
set motor_pwm_inversion = OFF
set motor_poles = 14
set motor_output_reordering = 2,3,0,1,4,5,6,7
set thr_corr_value = 0
set thr_corr_angle = 800
set failsafe_delay = 15
set failsafe_off_delay = 10
set failsafe_throttle = 1000
set failsafe_switch_mode = STAGE1
set failsafe_throttle_low_delay = 100
set failsafe_procedure = DROP
set failsafe_recovery_delay = 10
set failsafe_stick_threshold = 30
set align_board_roll = 0
set align_board_pitch = 0
set align_board_yaw = 0
set bat_capacity = 0
set vbat_max_cell_voltage = 420
set vbat_full_cell_voltage = 410
set vbat_min_cell_voltage = 330
set vbat_warning_cell_voltage = 350
set vbat_hysteresis = 1
set current_meter = ADC
set battery_meter = ADC
set vbat_detect_cell_voltage = 300
set use_vbat_alerts = ON
set use_cbat_alerts = OFF
set cbat_alert_percent = 10
set vbat_cutoff_percent = 100
set force_battery_cell_count = 0
set vbat_display_lpf_period = 30
set vbat_sag_lpf_period = 2
set ibat_lpf_period = 10
set vbat_duration_for_warning = 0
set vbat_duration_for_critical = 0
set vbat_scale = 110
set vbat_divider = 10
set vbat_multiplier = 1
set ibata_scale = 100
set ibata_offset = 0
set ibatv_scale = 0
set ibatv_offset = 0
set beeper_inversion = ON
set beeper_od = OFF
set beeper_frequency = 0
set beeper_dshot_beacon_tone = 3
set yaw_motors_reversed = OFF
set mixer_type = LEGACY
set crashflip_motor_percent = 0
set crashflip_expo = 35
set 3d_deadband_low = 1406
set 3d_deadband_high = 1514
set 3d_neutral = 1460
set 3d_deadband_throttle = 50
set 3d_limit_low = 1000
set 3d_limit_high = 2000
set 3d_switched_mode = OFF
set reboot_character = 82
set serial_update_rate_hz = 100
set imu_dcm_kp = 2500
set imu_dcm_ki = 0
set small_angle = 180
set imu_process_denom = 2
set auto_disarm_delay = 5
set gyro_cal_on_first_arm = OFF
set gps_provider = UBLOX
set gps_sbas_mode = AUTO
set gps_auto_config = ON
set gps_auto_baud = OFF
set gps_ublox_mode = AIRBORNE
set gps_ublox_use_galileo = OFF
set gps_set_home_point_once = ON
set gps_use_3d_speed = OFF
set gps_sbas_integrity = OFF
set gps_rescue_min_start_dist = 30
set gps_rescue_alt_mode = MAX_ALT
set gps_rescue_initial_climb = 10
set gps_rescue_ascend_rate = 750
set gps_rescue_return_alt = 30
set gps_rescue_ground_speed = 750
set gps_rescue_max_angle = 70
set gps_rescue_roll_mix = 150
set gps_rescue_pitch_cutoff = 75
set gps_rescue_descent_dist = 50
set gps_rescue_descend_rate = 120
set gps_rescue_landing_alt = 4
set gps_rescue_disarm_threshold = 25
set gps_rescue_throttle_min = 1100
set gps_rescue_throttle_max = 1700
set gps_rescue_throttle_hover = 1275
set gps_rescue_sanity_checks = RESCUE_SANITY_FS_ONLY
set gps_rescue_min_sats = 5
set gps_rescue_allow_arming_without_fix = OFF
set gps_rescue_throttle_p = 15
set gps_rescue_throttle_i = 15
set gps_rescue_throttle_d = 20
set gps_rescue_velocity_p = 8
set gps_rescue_velocity_i = 40
set gps_rescue_velocity_d = 12
set gps_rescue_yaw_p = 20
set deadband = 5
set yaw_deadband = 5
set yaw_control_reversed = OFF
set pid_process_denom = 2
set runaway_takeoff_prevention = ON
set runaway_takeoff_deactivate_delay = 500
set runaway_takeoff_deactivate_throttle_percent = 20
set simplified_gyro_filter = ON
set simplified_gyro_filter_multiplier = 100
set tlm_inverted = OFF
set tlm_halfduplex = ON
set hott_alarm_int = 5
set pid_in_tlm = OFF
set report_cell_voltage = OFF
set telemetry_disabled_voltage = OFF
set telemetry_disabled_current = OFF
set telemetry_disabled_fuel = OFF
set telemetry_disabled_mode = OFF
set telemetry_disabled_acc_x = OFF
set telemetry_disabled_acc_y = OFF
set telemetry_disabled_acc_z = OFF
set telemetry_disabled_pitch = OFF
set telemetry_disabled_roll = OFF
set telemetry_disabled_heading = OFF
set telemetry_disabled_altitude = OFF
set telemetry_disabled_vario = OFF
set telemetry_disabled_lat_long = OFF
set telemetry_disabled_ground_speed = OFF
set telemetry_disabled_distance = OFF
set telemetry_disabled_esc_current = ON
set telemetry_disabled_esc_voltage = ON
set telemetry_disabled_esc_rpm = ON
set telemetry_disabled_esc_temperature = ON
set telemetry_disabled_temperature = OFF
set telemetry_disabled_cap_used = ON
set ledstrip_visual_beeper = OFF
set ledstrip_visual_beeper_color = WHITE
set ledstrip_grb_rgb = GRB
set ledstrip_profile = STATUS
set ledstrip_race_color = ORANGE
set ledstrip_beacon_color = WHITE
set ledstrip_beacon_period_ms = 500
set ledstrip_beacon_percent = 50
set ledstrip_beacon_armed_only = OFF
set ledstrip_brightness = 100
set osd_units = METRIC
set osd_warn_bitmask = 8191
set osd_rssi_alarm = 20
set osd_link_quality_alarm = 80
set osd_rssi_dbm_alarm = -60
set osd_rsnr_alarm = 4
set osd_cap_alarm = 2200
set osd_alt_alarm = 100
set osd_distance_alarm = 0
set osd_esc_temp_alarm = 0
set osd_esc_rpm_alarm = -1
set osd_esc_current_alarm = -1
set osd_core_temp_alarm = 70
set osd_ah_max_pit = 20
set osd_ah_max_rol = 40
set osd_ah_invert = OFF
set osd_logo_on_arming = OFF
set osd_logo_on_arming_duration = 5
set osd_tim1 = 2560
set osd_tim2 = 2561
set osd_vbat_pos = 234
set osd_rssi_pos = 234
set osd_link_quality_pos = 2112
set osd_link_tx_power_pos = 234
set osd_rssi_dbm_pos = 234
set osd_rsnr_pos = 234
set osd_tim_1_pos = 234
set osd_tim_2_pos = 2103
set osd_remaining_time_estimate_pos = 234
set osd_flymode_pos = 2125
set osd_anti_gravity_pos = 234
set osd_g_force_pos = 234
set osd_throttle_pos = 2157
set osd_vtx_channel_pos = 234
set osd_crosshairs_pos = 205
set osd_ah_sbar_pos = 206
set osd_ah_pos = 78
set osd_current_pos = 234
set osd_mah_drawn_pos = 234
set osd_wh_drawn_pos = 234
set osd_motor_diag_pos = 234
set osd_craft_name_pos = 2090
set osd_pilot_name_pos = 234
set osd_gps_speed_pos = 2130
set osd_gps_lon_pos = 2048
set osd_gps_lat_pos = 2065
set osd_gps_sats_pos = 2144
set osd_home_dir_pos = 2318
set osd_home_dist_pos = 2168
set osd_flight_dist_pos = 234
set osd_compass_bar_pos = 234
set osd_altitude_pos = 2135
set osd_pid_roll_pos = 234
set osd_pid_pitch_pos = 234
set osd_pid_yaw_pos = 234
set osd_debug_pos = 234
set osd_power_pos = 234
set osd_pidrate_profile_pos = 234
set osd_warnings_pos = 14667
set osd_avg_cell_voltage_pos = 2080
set osd_pit_ang_pos = 234
set osd_rol_ang_pos = 234
set osd_battery_usage_pos = 234
set osd_disarmed_pos = 234
set osd_nheading_pos = 234
set osd_up_down_reference_pos = 205
set osd_ready_mode_pos = 234
set osd_esc_tmp_pos = 234
set osd_esc_rpm_pos = 234
set osd_esc_rpm_freq_pos = 234
set osd_rtc_date_time_pos = 234
set osd_adjustment_range_pos = 234
set osd_flip_arrow_pos = 2222
set osd_core_temp_pos = 234
set osd_log_status_pos = 234
set osd_stick_overlay_left_pos = 234
set osd_stick_overlay_right_pos = 234
set osd_stick_overlay_radio_mode = 2
set osd_rate_profile_name_pos = 234
set osd_pid_profile_name_pos = 234
set osd_profile_name_pos = 234
set osd_rcchannels_pos = 234
set osd_camera_frame_pos = 35
set osd_efficiency_pos = 234
set osd_total_flights_pos = 234
set osd_aux_pos = 234
set osd_sys_goggle_voltage_pos = 234
set osd_sys_vtx_voltage_pos = 234
set osd_sys_bitrate_pos = 234
set osd_sys_delay_pos = 234
set osd_sys_distance_pos = 234
set osd_sys_lq_pos = 234
set osd_sys_goggle_dvr_pos = 234
set osd_sys_vtx_dvr_pos = 234
set osd_sys_warnings_pos = 234
set osd_sys_vtx_temp_pos = 234
set osd_sys_fan_speed_pos = 234
set osd_stat_bitmask = 14124
set osd_profile = 1
set osd_profile_1_name = -
set osd_profile_2_name = -
set osd_profile_3_name = -
set osd_gps_sats_show_hdop = ON
set osd_displayport_device = MSP
set osd_rcchannels = -1,-1,-1,-1
set osd_camera_frame_width = 24
set osd_camera_frame_height = 11
set osd_stat_avg_cell_value = OFF
set osd_framerate_hz = 12
set osd_menu_background = TRANSPARENT
set osd_aux_channel = 1
set osd_aux_scale = 200
set osd_aux_symbol = 65
set osd_canvas_width = 30
set osd_canvas_height = 13
set osd_craftname_msgs = OFF
set task_statistics = ON
set debug_mode = GYRO_SCALED
set rate_6pos_switch = OFF
set cpu_overclock = OFF
set pwr_on_arm_grace = 5
set enable_stick_arming = OFF
set vtx_band = 0
set vtx_channel = 0
set vtx_power = 0
set vtx_low_power_disarm = OFF
set vtx_softserial_alt = OFF
set vtx_freq = 0
set vtx_pit_mode_freq = 0
set vtx_halfduplex = ON
set vcd_video_system = AUTO
set vcd_h_offset = 0
set vcd_v_offset = 0
set max7456_clock = NOMINAL
set max7456_spi_bus = 2
set max7456_preinit_opu = OFF
set displayport_msp_col_adjust = 0
set displayport_msp_row_adjust = 0
set displayport_msp_fonts = 0,0,0,0
set displayport_msp_use_device_blink = OFF
set displayport_max7456_col_adjust = 0
set displayport_max7456_row_adjust = 0
set displayport_max7456_inv = OFF
set displayport_max7456_blk = 0
set displayport_max7456_wht = 2
set esc_sensor_halfduplex = OFF
set esc_sensor_current_offset = 0
set led_inversion = 0
set pinio_config = 1,1,1,1
set pinio_box = 255,255,255,255
set usb_hid_cdc = OFF
set usb_msc_pin_pullup = ON
set flash_spi_bus = 3
set rcdevice_init_dev_attempts = 6
set rcdevice_init_dev_attempt_interval = 1000
set rcdevice_protocol_version = 0
set rcdevice_feature = 0
set gyro_1_bustype = SPI
set gyro_1_spibus = 1
set gyro_1_i2cBus = 0
set gyro_1_i2c_address = 0
set gyro_1_sensor_align = CW90FLIP
set gyro_1_align_roll = 0
set gyro_1_align_pitch = 1800
set gyro_1_align_yaw = 900
set gyro_2_bustype = SPI
set gyro_2_spibus = 0
set gyro_2_i2cBus = 0
set gyro_2_i2c_address = 0
set gyro_2_sensor_align = CW0
set gyro_2_align_roll = 0
set gyro_2_align_pitch = 0
set gyro_2_align_yaw = 0
set i2c1_pullup = OFF
set i2c1_clockspeed_khz = 800
set i2c2_pullup = OFF
set i2c2_clockspeed_khz = 800
set i2c3_pullup = OFF
set i2c3_clockspeed_khz = 800
set mco2_on_pc9 = OFF
set scheduler_relax_rx = 25
set scheduler_relax_osd = 25
set serialmsp_halfduplex = OFF
set timezone_offset_minutes = 0
set rpm_filter_harmonics = 3
set rpm_filter_q = 500
set rpm_filter_min_hz = 100
set rpm_filter_fade_range_hz = 50
set rpm_filter_lpf_hz = 150
set stats_min_armed_time_s = -1
set stats_total_flights = 0
set stats_total_time_s = 0
set stats_total_dist_m = 0
set craft_name = Cinelog35 V2
set pilot_name = -
set altitude_source = DEFAULT
set altitude_prefer_baro = 100
set altitude_lpf = 300
set altitude_d_lpf = 100
set box_user_1_name = -
set box_user_2_name = -
set box_user_3_name = -
set box_user_4_name = -
profile 0
profile 0
set profile_name = 6S
set dterm_lpf1_dyn_min_hz = 71
set dterm_lpf1_dyn_max_hz = 142
set dterm_lpf1_dyn_expo = 5
set dterm_lpf1_type = PT1
set dterm_lpf1_static_hz = 71
set dterm_lpf2_type = PT1
set dterm_lpf2_static_hz = 142
set dterm_notch_hz = 0
set dterm_notch_cutoff = 0
set vbat_sag_compensation = 0
set pid_at_min_throttle = ON
set anti_gravity_gain = 100
set anti_gravity_cutoff_hz = 5
set anti_gravity_p_gain = 100
set acc_limit_yaw = 0
set acc_limit = 0
set crash_dthreshold = 50
set crash_gthreshold = 400
set crash_setpoint_threshold = 350
set crash_time = 500
set crash_delay = 0
set crash_recovery_angle = 10
set crash_recovery_rate = 100
set crash_limit_yaw = 200
set crash_recovery = OFF
set iterm_rotation = OFF
set iterm_relax = RP
set iterm_relax_type = SETPOINT
set iterm_relax_cutoff = 17
set iterm_windup = 85
set iterm_limit = 400
set pidsum_limit = 500
set pidsum_limit_yaw = 400
set yaw_lowpass_hz = 100
set throttle_boost = 3
set throttle_boost_cutoff = 15
set p_pitch = 59
set i_pitch = 160
set d_pitch = 46
set f_pitch = 159
set p_roll = 38
set i_roll = 102
set d_roll = 29
set f_roll = 101
set p_yaw = 38
set i_yaw = 102
set d_yaw = 0
set f_yaw = 101
set angle_level_strength = 50
set horizon_level_strength = 50
set horizon_transition = 75
set level_limit = 55
set horizon_tilt_effect = 75
set horizon_tilt_expert_mode = OFF
set abs_control_gain = 0
set abs_control_limit = 90
set abs_control_error_limit = 20
set abs_control_cutoff = 11
set use_integrated_yaw = OFF
set integrated_yaw_relax = 200
set d_min_roll = 29
set d_min_pitch = 46
set d_min_yaw = 0
set d_max_gain = 37
set d_max_advance = 20
set motor_output_limit = 100
set auto_profile_cell_count = 0
set launch_control_mode = NORMAL
set launch_trigger_allow_reset = ON
set launch_trigger_throttle_percent = 20
set launch_angle_limit = 0
set launch_control_gain = 40
set thrust_linear = 0
set transient_throttle_limit = 0
set feedforward_transition = 0
set feedforward_averaging = 3_POINT
set feedforward_smooth_factor = 25
set feedforward_jitter_factor = 7
set feedforward_boost = 15
set feedforward_max_rate_limit = 88
set dyn_idle_min_rpm = 40
set dyn_idle_p_gain = 50
set dyn_idle_i_gain = 50
set dyn_idle_d_gain = 50
set dyn_idle_max_increase = 150
set level_race_mode = OFF
set simplified_pids_mode = RPY
set simplified_master_multiplier = 85
set simplified_i_gain = 150
set simplified_d_gain = 115
set simplified_pi_gain = 100
set simplified_dmax_gain = 0
set simplified_feedforward_gain = 100
set simplified_pitch_d_gain = 140
set simplified_pitch_pi_gain = 150
set simplified_dterm_filter = ON
set simplified_dterm_filter_multiplier = 95
set tpa_mode = D
set tpa_rate = 60
set tpa_breakpoint = 1250
rateprofile 0
rateprofile 0
set rateprofile_name = -
set thr_mid = 50
set thr_expo = 0
set rates_type = ACTUAL
set quickrates_rc_expo = OFF
set roll_rc_rate = 5
set pitch_rc_rate = 5
set yaw_rc_rate = 5
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 62
set pitch_srate = 62
set yaw_srate = 62
set throttle_limit_type = OFF
set throttle_limit_percent = 100
set roll_rate_limit = 1998
set pitch_rate_limit = 1998
set yaw_rate_limit = 1998
set roll_level_expo = 0
set pitch_level_expo = 0
end the command batch
batch end
SAVE
Thanks, that looks like you are using the stock CLI for 4.4.2 and I cant see anything wrong with it from a quick scan, so the next thing is if you can send me the blackbox log for the flight you have in the video, that way we can double check that to try and figure it out from there to see if we can see what still needs to be tuned on your craft.
Can you also confirm your quad is using the 2650KV motors and are running on a 6S battery? If so can you let me know what specific battery size too?
Finally I suggest you take a look at this tool to try and get the parameters tuned abit more to your preferences - https://fpv-drone.info/tools/tuning-tools/
Kind Regards
Hi Alex,
Sorry for the late reply, busy with work at the moment so difficult to put some time a side to look at this.
The motors are the 2650 and are running on the 6s GN3, 1300 120c batteries.
The black box info I’ll get for you when I get chance, just one other thing that may help with a solution, it seems when you cut throttle when doing a split s or similar movements the quad starts to shake, if you add in a small amount of throttle this stops, not something i’ve ever noticed from any of my other drones, any ideas based on this.
Thanks, that last comment may be the key to the issue. Could you double check your betaflight issues to check if you have dynamic idle set, and if so what the values are, as increasing this may help to give the motors more authority to correct itself when your throttle is low:
For more info, please see:
Otherwise let me know when you can get the logs so we can look into that abit more.
Hi Alex,
Again sorry for the late reply, really busy with work, not really getting much time to sort this.
I’ve looked and Dynamic Idle is set, the throttle and motor settings are -
Throttle Boost - 3
Motor Output Limit - 100
Dynamic Idle - 40
As for changing any of this, I have absolutely no idea what I’m doing, from reading the guide it would seem some knowledge on messing with these values is needed without buggering things up more!
With the request for the black box info, again I really don’t have any idea what or how to get this off the drone.
This really is why I bought a pre built drone and went for the Cinelog 35 as the reports on the tune and flight performance were very good straight out the box, this sadly isn’t what I’m finding on this drone as it shakes like hell as soon as the motors spin down or there’s the slightest of breeze (and I mean breeze not wind).
I currently have a Mark 5 in the 5" Geprc range which is perfect and a DJI Avatar in the cinewoop genre, which fly’s so much better with pretty good stability in comparison to the 35 which I’m sure cant be right?? Are you sure this is a tuning issue and not a fault with the drone?
**Just dug out the Avatar to see if it was just me as not used it for a while and honestly its a night and day difference, the 35 fly’s really badly!
Hi, just to update you, we are waiting on some feedback from GepRC, as tuning a quad is something a little beyond the scope of support we offer given the complexity and time required for this, so hopefully GepRC will be able to provide some feedback. I will update you as soon as they get back to us!
Kind Regards
Hi Alex,
Thanks for getting back to me. I have already gone down the contacting Geprc route, they offered a new CLI file, asked for me to check the dynamic balance on the motors, assessed the videos I uploaded for them, before and after, and came to the conclusion they would need to have the drone returned to China to physically test as they could not come up with a resolve.
As I raised this issue as soon as I flew the drone for the first time after purchase, I don’t want to be involved in sorting the issue with Geprc or anyone else now, as this is really dragging on, and is clearly an issue with this particular drone as you shouldn’t need to re-design the entire flight profile through Betaflight just to get it to fly ok.
I have requested through your main website either an exchange or refund, exchange for a new unit that works would be better for me as it will save time waiting for a refund then repurchasing as I would like to be able to use the quad while were still in the summer period.
Is this something you can organise as again, this should really be an issue you can deal with directly with your supplier due to it being a very recent purchase.
Note: On return you are more than welcome to test the drone for yourselves, I can guarantee you will find there is an issue with the drone.
I look forward to hearing from you.
Chris Boaler
I’m sorry to hear about the trouble you’re having. Tuning is a bit beyond the support we can offer, as it often comes down to individual preferences, the manufacturer’s settings, and Betaflight software, which isn’t controlled by us or the manufacturer.
I understand that a poor default tune isn’t ideal, but it doesn’t necessarily mean the product is faulty—just that GepRC may not have optimized their default settings. If you’re unhappy with the drone’s performance because of this, we can accept it back as a change of mind return. We’re happy to extend our 30-day return limit for you in this case, given you reported this issue a while ago. The refund will be based on the condition of the drone and how long you’ve had it.
That said, tuning is usually something pilots do to suit their specific setup and camera. Cinewhoops, in particular, can be tricky to tune, especially for outdoor flying. But we’re here to help you as much as possible.
To help us assist you further, could you confirm that you’ve loaded the GepRC CLI files from this page: GepRC CLI Files? If you have, it would be great if you could send me a blackbox log from the flight in your video. This would help me check for any issues more closely.
In addition, the flight behavior you’re experiencing could also be caused by several other factors unrelated to the tune. Please check for:
  • Damaged or chipped props
  • Loose screws or components
  • A camera that might not be securely attached
  • Radio transmitter issues or settings
If you’ve checked all of these and are still having issues, you can return the drone to us. However, please note that if the issue is due to incorrect settings, we might not be able to offer a full refund, as tuning PIDs is a chargeable service. If we find there’s a hardware fault, we’ll, of course, repair, replace, or refund the item for you.
To help us figure out the next best steps, please send over the blackbox log from the flight video.
Looking forward to your reply.
Kind Regards
Hi Alex,
I would just like to return the drone, not as a ‘change of mind return’ but as faulty.
I’ve already explained further up the thread, on a number of occasions what I have tried both from yours, and Geprc’s stance as to how to potentially rectify the issue and the fault still remains, this isn’t a tune issue as (again) I have reloaded there new CLI files which in Geprc’s words 'should have solved any flight and camera wobble issues, they determined there must be a fault with the drone, either something with the motors (dynamic balance) or something else, sadly they don’t know without seeing the drone.
As this was a new purchase and reported straight away, I would like either an exchange for a replacement model or my money back in full, with either option you should then be able to send the faulty unit back to Geprc without question.
As I stated before, if you can organise for the return of this drone to your facility you can test the unit for yourself as this is taking up way to much time to sort.
I look forward to hearing from you so we can progress this matter.
To clarify -
  • Damaged or chipped props - Tried both sets as recommended.
  • Loose screws or components - Checked all visible screws, I’m not dismantling the unit to look inside!
  • A camera that might not be securely attached - Checked fitting, all good.
  • Radio transmitter issues or settings - No issues, I have two other drones, one DJI, one Geprc, both use the 03 air unit and both work absolutely fine.
Chris Boaler.
My suggestion would be to first send us over the blackbox log from a flight that demonstrates this issue so we can figure out what is causing the issue, as this will be much faster than returning it back for us to check over etc… as again based on what I have seen i am 99% certain this is just a config issue, and not actually a faulty product. I am only suggesting this as if we get the drone back and find its an issue with config then you would need to pay the postage fees, and possibly the configuration time for us to get the drone tuned for you.
Should you wish to proceed with the return I will get an RMA sent over to you, however if you can spare 5min first, its best to send over the blackbog log from a flight that demonstrates the issue so we can first double check to confirm if its faulty or not, and possibly even provide the solution remotely.
Kind Regards
  1. Your RMA number
  2. A link to our RMA form
Kind Regards
Hi Alex,
I don’t think I set the drone up in Betaflight to store black box data, and to be honest even it it was I’m not sure how to retrieve it so I’d just like to send it back to you to have a look at, as I’m sure if there is data to retrieve you will be far more adept at accessing it.
I appreciate if this is an issue my end that I may have to pay but I really don’t think this is the case following all the things I have tried and the discussions I’ve had with Geprc’s tech team.
To let you know, the email that is sent with the RMA number etc has not come through, can you send again and let me know when so I can check again to see if its arrived.
Thanks in advance.
Chris.
No problem, thanks for clarifying, we will check once we get it back!
I have just resent the email to you now, otherwise please check spam… I have sent it to the email address used on your order. Any issues, please let me know.
Kind Regards
Hi Alex,
Thanks for resending the link, I’ve filled in all the info and tried to retrieve the prepaid Royal Mail returns label info but an error keeps popping up when retrieving the label, when reloading the page to go back to try filling in again the form is saying Access denied, can you help?
Sorry, sorted, just needed to use another browser.
Happy to hear that, once we get the item back and have completed our inspection we will let you know
Kind Regards
