Hi, I’m using a mini unmanned hawk purchased from yourselves as part of a university project.
Our design is a flying wing with two separate elevators. I managed to program our radio transmitter to set s2 and s4 on the main out rail to control the two elevators, but the ailerons have been set to channels 1 and 6. S1 works fine but when I plug a servo into s6 I dont get a physical output. Mission planner shows that the radio 6 channel is getting a signal but it isn’t pushing it through to the servo.
The servo is getting power as when I arm the autopilot it moves into the neutral position, and I tested the same servo in s1 where it worked. So for some reason the autopilot isn’t sending a signal to s6, any idea how I can correct this? I can’t change the channel on the radio transmitter from 6, it is factory set.
