Happymodel Releases TXCO EP series ELRS receivers for improved performance and range
EP1, EP2, ELRS receiver is the hottest Tiny Express LRS receiver on the market since it was released. But the new TCXO version EP series receivers apply “Temperature-Compensated Crystal Oscillator”, which accurately maintains the radio’s frequency in extreme temperature environments, making these TCXO much more reliable.
Pricing is slightly more expensive than the current series receivers due to the more expensive crystal, but overall still one of the most affordable ELRS receivers on the market.
Specifications
EP1 TCXO Receiver
Type: ISM2.4GHz
ESP8285 MCU
SX1280(SX1281)IMLTRT RF Module
Omni directional antenna
Frequency Range: 2400 MHz to 2500 MHz
Receive refresh rate: 25HZ~500Hz
Working voltage: 5v
Weight: 0.41 gram(without antenna)
Dimension: 10mm10mm6mm
Peak gain: 2.23dB
Default Firmware out of factory: HappyModel_EP_2400_RX V2.2 version
Built-in a TCXO (temperature compensated crystal oscillator)
EP2 TCXO Receiver
Type: ISM2.4GHz
ESP8285 MCU
SMD Ceramic antenna
Working voltage: 5v
Weight: 0.44 gram
Peak gain: 3.7dB
EP1 Dual TCXO Receiver
Type: ISM2.4GHz
ESP32 PICO D4, dual SX1280(SX1281)
Antenna connector: IPEX MHF 1/U.FL
RF Frequency: 2.4GHz (2400~2480MHz)
Telemetry power: >19dbm
Receiver protocol: CRSF
Input voltage: +5V DC @ “+” pad
PCB size: 19mm x 14mm
Weight: 1gram exclude antenna
Default Firmware out of factory: Unified_ESP32_2400_RX Could upgrade to HappyModel EP1 Dual 2400 RX 3.0FW
Where To Buy
  • Unmanned Tech
    If you have another link you want me to add here just add it below.
