The preferred gimbals in industrial applications are generally as light as possible to give long flight time. However, there are still heavy commercial cameras that need a large but versatile gimbal to carry them. Gremsy T7 can be what you’re looking for.
Gremsy T7 is a robust gimbal designed for heavy-lift industrial drones. Featuring a carrying capacity of 7 lbs, the T7 can be fitted with an optional extra camera slide for versatile multi-sensor operation. Built-in HDMI Hyper Quick Release functionality enables connection with just a push and twist-lock movement, allowing hot-swapping within seconds as well as the ability to withstand thousands of mating cycles.
With a large camera cage, the T7 is compatible with a wide range of cameras and payloads from leading manufacturers such as Phase One iMX, Wiris GIS 320, Corocam 8 UAV, Specim AFX10/17, etc,.
Gremsy T7 joined in the setup with Acecore Technologies Neo Drone and Workswell GIS320 camera to conduct gas detection mission.
https://www.youtube.com/watch?v=Nwnilc-HcIE
