Iāll try to convince you to go with a proper 1s build since itās winter and you likely wonāt fly much outside anyway. for another couple of months and thereās a lot of compromises youād have to make if you wanted a hybrid. 1s is all about minimum weight (the parts you listed would barely take off on 1s
) and with 2s you want better camera/VTX/RX because you will fly faster and further. You will also want more durability for 2s because it will carry much more momentum in crashes.
Havenāt tried them personally, but Iāve seen them recommended by people I trust (afaik these are not a rebrand of HappyModel motors), but 15000kv wonāt really work on 1s unless you go mental with keeping weight down (~15-16g max + quad-blade props would work). Iād go with 19500kv which is optimal for 1s and then use a throttle output limit of about 60-70% when flying it on 2s.
Thatās definitely the one you want to go with if you really want 2s hybrid as itās the most durable one. You might need to get creative with battery mounting for 2s though, but they also have a 2s version that accepts 2 x 1s stick batteries. Itās not bad for 1s but thereās a better (lighter and higher battery placement for better CG) and newer option, also from BetaFPV - Meteor65 frame.
Itās an awkward solution for the triangle-shaped VTX and a EOS2 camera neither of which are that great. More about that under camera.
Iām very biased against Crazybees because I havenāt had a single one out of ~15 last more than ~5 flights. BetaFPV is the way to go in my opinion. They have a great new 1s-only board at 2.67g which has proven super reliable so far in several builds over last couple of months for me so I would whole-heartedly recommend that but obviously it wonāt work if you really want 2s.
While it has a nicer picture than most whoop AIO cameras in perfect conditions, itās really bad at light handling and is very prone to jello at sunlight. In my opinion not worth its weight - if you want to focus on 2s then RunCam Nano 2 is a much better camera. If you go 1s, then get any AIO camera/VTX and depending on which one you get, that will influence your choice of camera mount and/or canopy. The best of the best is FX950TW which comes with a 3d printed mount and if you want extra protection then a clear TW Razor Skin canopy has proven the toughest. Most other cameras will fit into NBD beeeye mount (some cameras might require cutting the mount a bit) but be careful with AIOs which have antenna sticking up, you will probably want to secure those additionally.
Hell for mounting. You want to keep the profile as low as possible and this one will require at least 5mm extra height. You want something tiny that you can stick inside the canopy or underneath the fc. BetaFPV has a new AIO that doesnāt have the best camera (they arenāt really known for making good cameras), but I am seriously impressed with its VTX performance. It comes with two mounts and you can use a BetaFPV canopy for extra protection if needed (those break easily, but you can get 5-packs via AliExpress for peanuts - get clear ones as those are toughest). Hereās an example video feed from this VTX vs. from your average whoop AIO VTX.
At 3g thatās almost 20% of my lightest whoopās weight. You really donāt want that kind of weight even on 2s, and especially not on 1s. There are some ~1g DVR boards (and there are some VTX/DVR combos) but in my opinion they arenāt that much better than goggle DVR. They often lose entire recordings, skip frames etc.
Built in RX will be fine for 99% of things you will do with a 1s whoop. With 2s you might want to push extra range so yeah Iād go with external RX and 200mw + VTX in that case. I generally have terrible experience with anything built by HappyModel. BetaFPV is my favourite whoop part makes as their parts are fairly reliable (not perfect) and their customer support had been very helpful with providing replacement parts + free extras a few times when I had issues.
Thatās a lot of text, sorry, Iām a bit passionate about micros
Oh andā¦
Motors arenāt an issue, you can always use higher KV than required with a throttle limit, but Mobula6 FC/ESC isnāt rated for 2s input so it wouldnāt work.
