I tried to use the impluseRC but it just says its searching and searching.
In my device manager it says I have SILCON Labs cp210x usb uart bridge…
it does not show the STM32 Boot loader device within the device manager. because I tried to follow the update the drive…
ive tried so many things to get this to flash… I still cant get the latest version on clean flight to connect. BUT I was able to get it to connect with version 1.2 something… but even then I still cant update the firmware. I also tried that Zadig and when I list all devices it shows the USB UART driver. not the stm32 driver… any ideas? are you close to Cincinnati ohio and up for a challenger lol?
dean
also is there a place I can download this stm32 bootloader?
You might want to try flashing the firmware .hex file directly via stm32 dfuse demonstrator software… there a a bunch of YouTube videos showing how to do this as it’s relatively easy to follow. Let me know if that works or not
that’s what I ended up finding a video for and it seems to of worked. I have the latest version of CF installed and firmware.
but the Magnetometer wont show up in cleanflight. its grayed out…any thoughts?
Do you have a Mag. on the board?
Some boards don’t, as external mags are getting common now.
What board do you have?
Steve
As Steve said, maybe your board doesnt have one. But if you let me know what board it is, or prefferably send a photo I can see if it has one or not… Otherwise you do need to enable the mag setting within the configuration tab in betaflight/cleanflight.
i sent 2 pictures. hope this helps. I dotn even know if I need this. I bought it as a kit. every step of the way has been some sorta ordeal… anyone need a quad kit? ha ah
while I’m at it. and you two are the only ones on here. what’ s an ok radio to use… id like to get one at the local hobby shop or if you know of a good cheap one from china…
I’m probably being thick …
but where did you upload the photos, I can’t see them
Steve
I pressed reply to this email… do you see an attachment
I am not sure if attachments work if you use the reply by email feature, best to do it directly on this site…
