How to calibrate ESC's on my arducopter
Can you plz tell me how should I calibrate my ESC using radio telemetry and run my motors to fly in guided mode?
Can I power my apm using usb and run radio telemetry?
This is how you calibrate your ESC’s on a pixhawk based system: You actually dont connect it to your PC for this.
https://www.youtube.com/watch?v=6kfVusza17I
For more details on ESC calibration in general check out this ESC calibration guide
Thanks for your prompt reply but I’m using APM 2.8 and I don’t have RC control rather 433Mhz radio telemetry unit for communication with the board. How do I calibrate my ESC? Or How can I run motors ? Is it through MavLink?
No the ESC caibration is the same as pixhawk systems. You will need an R/C Radio to calibrate the ESC’s
There is no manual throttle as we are building it in guided mode. Is there an alternative without throttle??
You could use something like a servo tester to calibrate the ESC’s.
