How to set up rates and exponential settings when using the DJI RC 2
Thank you.
I have managed to sort this out.
On a separate note - are you able to advise how to set up rates and exponential settings when using the DJI RC 2? I know how to set this up in my ELRS Tx, however, not sure how this can be done in the DJI RC as it does not have any screen or settings on it.
Best,
Elon
You should be able to adjust the rates and expo settings within your FPV Goggles’ controller menu. However, if you encounter issues with the RC2 and O3 system not displaying the rates/expo menu, you can alternatively configure these settings in Betaflight. This allows you to change the rates and expo directly on the flight controller if you can’t manage it through the radio.
