Dear,
I should connect VTX in this connector(picture below). I do not know what it is and where to find?Is it call JST connector 6pin?Stock in europe?thanks
Dear,
No…
You have solder point on that FC already.
Top Right hand corner…
AGND RAM VOUT
AGND RAM VIN
AGND = Ground
RAM = Positive (Check the voltage on that pin… Dont fry anything)
VOUT = VTX
VIN = FPV Camera.
WARNING depending on the setup of your board that RAM pin can be as much as 14vdc if your running a 4S raw Lipo power.
Check the configuration and solder brigdes before powering up.
This is for FPV camera and VTX (Yes I talk about VTX, but i mean … this. How can I connect to the board?
I see.
Thats a Rx
In that case…
top right hand corner of the FC under the M3 Bolt.
The 3 Pins… J7 5V GND
GND - GND
VCC - 5V
I-BUS/S.BUS or PPM (Depending on which one you want) - J7 (PPM/SBUS)
That Rx will problemly have a breakout cable with it.
Yes but there is a problem, because the IBUS do not work on J7 (it is just for the frysky, and it is converted). So I need this marked connector?Where Can I buy?
So just wire up PPM
Blk - GND
Red - 5V
Yellow - J7
JST 1.0 4 wire connector. Google it and many will show up. Almost any place the sells RC stuff will have one.
Thanks for the link. But I try the PPM (UART6), but still nothing. I changed in RC radio to PPM and in betaflight configurator to PPM on the same connector (right corner)??
