Jumper T16 stuck on boot splash screen
If you have a situation where your Jumper T16 is not booting up properly, or is stuck on the splash screen where none of the buttons are working, this quite post will help you get it sorted.
This issus usually occus after a firmware update, and in some situations can occur after chaging settings via OpenTX companion.
After talking with Jumper they have reccomended the following to avoid this issue in the future:
So lets get onto the solution:
  1. Connect the radio to PC via USB (don’t pull out the SD card from T16)
  2. Please completely delete ALL files on the SD card
  3. Format the SD card
  4. Copy the following to the new SD card file in. You can download the file from here: https://www.jumper.xyz/portal.php?mod=view&aid=17
If you have any questions please let me know and I can try to help.
