I kid you not with this one…lol Imax B6 charger, i ordered it from the land of the rinsing Sun, well so i thought, it said it was a genuine one, code is on the back and its been confirmed from skyrc.com, in the mean time while i was waiting for my QX7 to arrive, i ordered FrSHY ni-MH battery pact AA2000maH 7.2V, everything came intacted…lol so i thought i’ll charge this battery pack up, i thought i’ll test it with my digital multi-meter first and it read 7.92 v, great so i thought…lol when i connected it up to the balance charger, it read 7.74 err i had to re-calibrate this so called Genuine charger, as anybody else had the same problem? with this pile of crap
Its not crap. Mine was the same way.
Hi Clifton, thanks for your reply…
Really so you to had to re-calibrate yours to Clifton, i would of thought that it would have been tested/calibrated at the factory where it was made or assembled, on the underneath it has a QC pass sticker on it too, how much did you have to re-calibrate yours then Clifton?..
is there a good way to use solar to charge li-po batteries
I don’t think a solar charger would be able to put out enough amps to change more than 1 lipo at a time ( I could be wrong )
It would be better to use solar to charge another larger battery and then use that to power the lipo charger and charge lipos
