For Matek F722 SE version
The manual says we need to insert 128 Mb MicroSD Card for the software.
But now a days 128 Mb MicroSD Card is just not available.
Hence, my query : Necessity of 128Mb MicroSD Card for F722 SE Flight Controller?
Betaflight should work with an 8Gb or 16Gb card but will only use 3.6Gb and fill the rest with a blank file if I remember correctly.
What is the max expandable memoryfor F722 SE?
Since I somewhere read it supports 128mb which is too low.
Will I be able to put 8gb sd card in the black box??
As I said a 8Gb or 16Gb card should be fine - but you will only be able to use 3.6Gb of the card - should last a while as most of my flights are around 22Mb in size
I use a 16Gb card with the Matek F405 and it’s fine.
Cool…
Thank you so much SIR…
