Hey Guys,
My Problem is that when i plug my Battery into my Quad one Motor starts to spin… (without beeing armed)
After i arm the Quad all Motors spins and work properly…
All Esc’s are calibrated and are brand new.
I dont want this Motor to spin when my Quad isnt armed…
Solder connections are double checked.
My setup:
Kiss Fc V1
FVT Little Bees 30A
Emax 2205S 2300kv
Video:
My default answer is to try flash blheli onto your ESC again, and check the settings as it almost seems like is in aircraft mode or something?
If flashing new firmware and syncing blheli settings does not work, then you might want to swap the ESC to another motor output to check that the issue is on the ESC and not the FC.
Thanks for your reply…
I will swap the signal Cables of my Quad to another Port…
Do you know if it is important that every Signal Cables are connected to the FC?
That would save some time
Hopefully it will work
I just soldered the Esc to another “Esc port”…
Looks like its an Esc related Problem because the same Motor has the same Problem…
Do you know if theres a way to calibrate non Kiss Esc’s with the Kiss fc?
I have not realy used Kiss FC stuff before so not much help… but can you connect via BLheli passthrough, as then you can just edit the max/min PWM rates directly in the software.
So you mean how we do it with every FC?
Plugging the FC in and opening BlHeli Suite?
That is my Problem… Kiss FC doesnt allow Flashthrough
I tried to do the Standard calibration procidure:
Setting min Throttle to 2000 etc… (You know the deal…)
Everything didnt work
Most betaflight FC do support pass-through, but otherwise then you need to use a USB linker and do each ESC one by one… Or the manual way using your RC controller.
However if you set it to use Dshot, then you dont technically dont need to do any calibration since this is digital (although the betaflght documentation says that it is best to still do a manual calibration before using Dshot just incase)
Sorry that I cant help much more as I am not very familiar with KISS stuff as I have never purchased one and we dont sell them either. That is not because they are bad… they are actually very nice but they do kind of force you to use KISS FC with KISS ESC and I am more of a fan of open source stuff. Although we will probably start selling KISS stuff one day as its on the long list of things to expand our catalog. Then one of us here will be a KISS expert. Anyways enough of my rambling on… Let me know if you figure it out or need any more help!
I just change the Esc Mode to DShot600…
Nothing is working right now
I tryed to do this Calibration precidure:
Settin min Throttle to 2000
arming
plugging battery in
etc…
Didnt work either…
Do you have any Ideas?
If not i think i will go back to Oneshot and/or buy Kiss Esc’s and Cry…
When you changed your ESC to Dhsot, did yo also change the setting on your KISS FC to dhsot 600 too? Or are you still struggling to connect your ESC to Blheli suite?
To be honest I have not used a KISS FC for a long time so cant help much here unfortunately , but you might want to ask the shop you purchased from as they should be able to help you figure this out.
Yeah… Thought about that too…
Im probably trying that and/or i will put another FC on it or put Kiss Esc’s on it…
Do you have a Betaflight FC that you can recommend?
