New hexacopter configuration
Hi!
I am thinking to build an hexacopter, I chose a possible configuration but I wonder if it is feasible or not, in particular I have some doubts about the motors…
I picked these components so far:
Frame: S550
https://hobbyking.com/en_us/s550-hex...0mm-black.html
Motors: Multistar 2814-700Kv
https://hobbyking.com/en_us/turnigy-...runner-v2.html
Prop: 1047
Esc: 30A
https://hobbyking.com/en_us/hobbykin...ontroller.html
Battery: 4S 10000mAh 10C
https://hobbyking.com/en_us/multista...lipo-pack.html
eCalc gives me this report:
which seems pretty good, what do you think?
Thank you
That looks good…
It might be worth trying a 5200mAHr battery in eCalc, the reduced weight compensates for the lower energy, you might find flight times not reduced much.
Steve :slight_smile:
Good point, also I found you can get good flight time improvements of you can find an optimal battery c rating for hover flight… since your motors are pulling about 20A in total (according to e calc) at hover, you could get away with a lower c battery which will be lighter (if you can find one) as I don’t think it’s easy to find ones lower than 10C
