Not showing up in beta flight
Order Number: #696140
Product Name: Betafpv Literadio 2 Se
Brand: BetaFPV
When bound to drone and the drone is plugged in to beta flight on the receiver tab when I use my transmitter it doesn’t work
I’ve done everything that the ai told me to do
Hi good day Samuel,
I’m sorry to hear you are battling to set-up your drone. These things can be a little tricky sometimes and usually its something simple we haven’t configured correctly.
I see you purchased the Elrs/Frsky Tx from us, yet you have CRSF selected in your photo, please try selecting the correct serial receiver for your drone.
If it is a ELRS I have attached the below guide for walking you through the process:
ExpressLRS (ERLS) Troubleshooting Guide
I also created a step-by-step guide for you using the Beta FPV radio:
To bind your BetaFPV LiteRadio 2 SE Transmitter (using ELRS or FrSky D8/D16) to your drone using Betaflight Configurator, follow these step-by-step instructions:
Step 1: Install Betaflight Configurator
  1. Download the Configurator: Go to the Betaflight GitHub releases page and download the latest version of Betaflight Configurator for your operating system.
  2. Install the Software: Follow the installation prompts to install the configurator on your computer.
Step 2: Connect Your Flight Controller
  1. Connect the Flight Controller: Use a USB cable to connect your flight controller to your computer. Ensure you’re using a data cable, not just a charging cable.
  2. Open Betaflight Configurator: Launch the Betaflight Configurator and select the appropriate COM port from the dropdown menu.
  3. Click Connect: Once connected, you should see the setup interface for your flight controller.
Step 3: Configure Receiver Settings
  1. Go to the Configuration Tab: In Betaflight Configurator, navigate to the “Configuration” tab.
  2. Select Receiver Mode: Under the “Receiver” section, select the appropriate receiver mode based on your transmitter:
  • For ELRS, choose “ELRS.”
  • For FrSky D8/D16, select “FrSky X.”
  1. Set Serial Ports: Navigate to the “Ports” tab and ensure that the UART port used for your receiver is configured correctly:
  • For ELRS, enable “Serial RX” on the corresponding UART.
  • For FrSky, enable “Serial RX” on UART where your receiver is connected.
  1. Save and Reboot: After making changes, click “Save and Reboot.”
Step 4: Binding Process
  1. Prepare Your Transmitter:
  • Turn on your LiteRadio 2 SE transmitter.
  • Set it to binding mode (check your transmitter’s manual for specific instructions).
  1. Power Up Your Drone**: Connect a LiPo battery to your drone to power it up.
  2. Initiate Binding:
  • For ELRS, follow the specific binding process as indicated in your ELRS documentation.
  • For FrSky, you may need to press a button on the receiver or use a specific stick command (usually throttle down and rudder right) while powering on the drone.
  1. Confirm Binding: Once binding is successful, you should see a confirmation on your transmitter (typically a solid LED light) indicating that it is bound to the receiver.
Step 5: Testing
  1. Check Receiver Inputs: Go back to Betaflight Configurator and navigate to the “Receiver” tab.
  2. Move Sticks and Switches: Move your sticks and toggle switches on the transmitter; you should see corresponding movements in Betaflight Configurator.
  3. Adjust Settings as Necessary: Make any necessary adjustments in Betaflight for channels or modes based on your preferences.
Step 6: Save Configuration
  1. Final Save: Once everything is set up and tested, click “Save Configuration” in Betaflight Configurator to ensure all settings are stored.
By following these steps, you should be able to successfully bind your BetaFPV LiteRadio 2 SE Transmitter with your drone using Betaflight Configurator.
Hope this helps sort out the issue you were having.
David
