Order Number: 697829
Product Name: Jumper T20s
Brand: Jumper
The edgetx system won’t load the expresslrs lua scripts and transmitter is stuck on loading screen when trying to
I’ve watched a video on how to sort it but still no resolve
Hi good day,
Thank you for reaching out to us regarding the issue you are experiencing with your Jumper. I understand how frustrating it can be when the system does not function as expected.
Let’s try a few troubleshooting steps to resolve this issue:
Check Firmware Version: Ensure that both your transmitter and the ExpressLRS module are running compatible firmware versions. Sometimes, mismatched versions can cause loading issues.
Reinstall Lua Scripts: Try deleting the current Lua scripts from your transmitter and reinstalling them. Make sure you are using the latest version of the scripts compatible with your firmware.
SD Card Check: Verify that your SD card is properly formatted and has enough space. Sometimes, a corrupted SD card can cause loading issues. Reformatting the card and reloading the necessary files might help. This is a very common issue so just check all is formatted accordingly and that the SD is not corrupt.
Factory Reset: If the above steps do not resolve the issue, consider performing a factory reset on your transmitter. Please ensure you back up any important data before proceeding with this step.
Consult the Manual: Refer to the user manual for any specific instructions related to Lua scripts and ExpressLRS setup.
If you have tried these steps and the issue persists, please let me know.
David
Any chance I could just have the transmitter sent back for repair or replacement I am super busy at the moment and that would be more convenient for me.
Hi good day,
We can definitely take a look at it for you, that’s not a problem. That’s why we have a team of technicians on-hand to assist.
Unfortunately, because we have such good technicians, word has spread and we are now sitting at about a 2 week backlog of work. So you would only get a response from us approximately 10 working days from when the controller arrives back at our warehouse.
If you would like to continue with the return, please see the below instructions.
An RMA (Return Merchandise Authorization) has been created for your order.
Your RMA number
A link to our RMA form
Hope this helps.
If you have any other questions, please do let us know?
David
The Problem
The loading screen gets stuck because the ExpressLRS configuration script cannot find an ELRS module to communicate with.
Solution Steps
1. Access Model Settings
- Open your model list
- Navigate to page 2 of the settings
2. Configure RF Module
- Locate the RF module settings
- You will see two options:
- Internal RF Module
- External RF Module
3. Enable CRSF Protocol
- If using internal module:
- Select the Internal RF Module
- Press ENTER
- Change the protocol to CRSF (Crossfire)
- If using external module:
- Follow the same steps but select External RF Module instead
4. Test the Script
- Return to the system menu
- Try running the ExpressLRS LUA script again
- It should now load properly instead of getting stuck
The root cause of this issue is typically having both RF modules turned off, which prevents the LUA script from finding a module to communicate with.
Hi that’s the video i watched but still didn’t work I have not had chance to send the controller back but I think I have “bricked” my esc if I was to send it back could this be repaired also?
I have also just received my parcel and the wrong item has been sent again this is the second time the same item has been sent wrong.
My order number is
UT-706836
I ordered the true rc mk2 antenna for the goggles v2 and again the goggles 2 antenna has been sent
I am really sorry Oliver!
Just to confirm you ordered this:
And received this?:
David
Yes I ordered the goggles v2 antenna.
Can you send a quick photo showing the antenna, and also the barcode on the package so we can make sure to resolve the issue on our side to avoid this issue going forward!
Sorry again about this, we will get it resolved for you I just want to make sure the issue is fixed before we go ahead and send a new one to you, otherwise we run the risk of the warehouse team having the same issue, especially if we have an incorrect barcode/label issue.
Kind Regards
I have checked again and I think the issue is that the Goggle 2 and Goggles V2 basically have the same barcode label, so this has caused a bunch of confusion, so what I will do is issue the refund for the antenna and if you can please return them again that would be much appreciated (you can use our prepaid returns label service again), however if you can use them just let me know and I can offer a partial refund for you to keep the ones you have.
Dont worry about the photos as we have resolved the issue internally now. Please just let me know how you wish to proceed with this re a refund or a partial refund and you keep the antennas.
Kind Regards
Hello thanks for that I can’t use them so I would like to send them back also could somebody get back to me about my other email regarding the controller being sent back for repairs and also my drone being sent back if it can be repaired.
Hi Oliver good day,
We have now completed the refunds for both of the antennas, which were incorrectly sent out to you.
If you can please return them when you have a moment, Alex will send an RMA number shortly.
As far as I can see we haven’t received any parcels from you, please can you send me the tracking information for them so i can follow that up for you?
Thank you so much for your assistance, it is really appreciated!
Can you please send me the
David
If anyone else has this issue… I had one just die like this too (from another UK store) with no way to fix, even they couldn’t fix it.
I tried all of these solutions recommended.
If none work it could just be that sometimes Jumpers Quality control is not as good as Radiomaster.
The pocket is similar sized in some ways other than the smaller gimbals.
The issue is due to a faulty internal TX so that needs to be replaced, hopefully the store will do this for you or issue a refund as we have encountered a number of units like this out from the factory. I think that Jumper has a policy of letting customers do the quality control checks for them as we have way more faulty jumper radios than other manufacturers like Frsky, or Radiomaster! But if you get a good one, then they are great radios as they have some cool ideas.
Kind Regards
Thanks for that they have issued me a refund
Yeah I want to avoid Jumper.
Imagine the fault developing mid flight.
Could it be bad antenna? or ipex/ufl coming loose due to bad connection?
Then transmitter fries.
Hi Kyle good day,
Connectors coming adrift from the PCB is unlikely for a radio but not impossible. Your radio shouldn’t be getting knocked or bounced around that much so the connectors usually stay in place.
I think their main issue is just the quality of their manufacturing and quality control afterwards, I know companies like RadioMaster and T-motor for example sell products at a higher price due to the number of QC checks they do along the way.
It’s time consuming work requiring skilled people, so it drives prices up.
Hope this helps.
David
If I was to order a drone could I have a receiver fitted to it before shipping and have the firmware updated?
Hi good day,
Yes, absolutely, we offer a full after-sales service which includes fault finding, repair and customisation.
This is a link to our engineering service ( per hour), which describes it in some more detail:
https://www.unmannedtechshop.co.uk/product/engineering-drone-build-customisation-fee/
You might be able to skip this entire step though, as we offer a stack of BNF (bind-and-fly) models which have an Rx already installed, and most of the time our pre-built drones, both PNP and BNF, are sold out so quickly they usually have the latest FW already pre-installed directly from the manufacturer. Most of the manufacturers also tune each model type and don’t just use BetaFlight presets.
Let me know what you would like to do and I can get that going for you?
David
