Order #697829 - Jumper T20s - Won’t load express lrs lua scripts
The Problem
The loading screen gets stuck because the ExpressLRS configuration script cannot find an ELRS module to communicate with.
Solution Steps
1. Access Model Settings
  • Open your model list
  • Navigate to page 2 of the settings
2. Configure RF Module
  • Locate the RF module settings
  • You will see two options:
    • Internal RF Module
    • External RF Module
3. Enable CRSF Protocol
  • If using internal module:
    • Select the Internal RF Module
    • Press ENTER
    • Change the protocol to CRSF (Crossfire)
  • If using external module:
    • Follow the same steps but select External RF Module instead
4. Test the Script
  • Return to the system menu
  • Try running the ExpressLRS LUA script again
  • It should now load properly instead of getting stuck
The root cause of this issue is typically having both RF modules turned off, which prevents the LUA script from finding a module to communicate with.
