Order Number: 703227
Product Name: Neutronrc At32f435 Mini 2s 12a Aio
Brand: NeuronRC
Hi i was just wondering what the target is for the inbuilt ELRS on the AIO as it is not SPI , I know on the manual it has a target : (DIY 2400 RX ESP8285 SX1280) however this does not exist , closest match i found is : Generic ESP8285 Full-duplex 2.4GHz RX as TX but this seems to be for a TX ? perhaps i am mis understanding .
Also when running 2S and trying to power EX1002 20,000Kv motors 3 motors spin but 1 refuses to spin , when testing each one individually i can get all motors to spin , what setting must i change on the ESC configurator to run these motors , if any ? currently running 1102 10,000Kv motors on 2S (works flawlessly) mostly just wanted to optimise for lower power draw
Hi good morning,
There have been some oddities coming through with some of the NeutronRC boards, lately and most of the issues have been due to AT32 firmware. I included the below snippet, just as reference as we have confirmed these issues with Neutron.
You obviously know your way around an AIO, and have done as I would have, I’ve reached out to Neutron and asked for their assistance. As soon as I hear back from them I will let you know.
David
Can you please try to reflash ELRS firmware onto the board, as that will likely resolve the issue
1,ELRS taget flash EMAX 2.4GHz/EMAX 2.4GHz RX
2,If the motor does not rotate, please try to increase the starting power of the motor on the ESC configurator, and let me know if that solves the issue.
Kind Regards
cool thanks , i have no issues with the elrs version flashed from factory , i just wanted to know what the correct target is just incase i need to update the firmware down the line but thank you for chasing that up with them . It might be worthwhile to mention on the unmanned site that the elrs target is this EMAX one because the manual has a completely different target .Again thank you for taking your time to help on my query’s i hope you have a wonderful weekend
Hi, good morning,
Not a problem, glad we could help!
David
